Done after 3-1/2 years of work
Kidasters
It took me long enough, but once the new fuel tank sending unit shows up, the Mini is finally roadworthy.
I made a list today, and here's what I've been doing:
What started 3-1/2 years ago as a simple carpet change out turned into so much more. Here's what I did in almost 4 years:
Replaced vinyl dash liner with grey leather
Re-built windshield wiper motor
Replaced headlight switch with correct switch
Replaced oil filter to "spin on" oil filter
Replace hard oil line from filter to pump with braided stainless line
Welded in new driver's side floor
Replaced rear turn signal lenses
Replaced rear lights with LED lights
Replaced Brake Master cylinder
Replaced Brake Booster
Replaced Clutch master cylinder
Replaced Clutch slave cylinder
Replaced Clutch actuator rod
Pulled and flushed radiator
Replaced radiator hoses
Replaced thermostat studs with ARP stainless studs
Replaced thermostat
Replaced heater valve
Replaced heater hoses
Changed water pump and belt
Changed fan
Changed distributor to electronic ignition distributor
Changed coil to "Flame thrower" coil
Changed alternator to 100 amp alternator
Changed ammeter to Voltmeter (smiths - it was as close as I could find)
Rebuilt speedometer. Had speedo refaced with MPH below KM/H scale
Replaced all dash lights with LED lights
Changed all flexible brake lines to stainless
Changed rear drums to "superfins"
Re-built front calipers. Installed slotted "S" rotors
Replace front wheel bearings.
Replaced all 4 shocks
Pulled fuel tank. Had it cleaned and internally coated.
Rebuilt HS2 carbs
Replaced throttle cable
Changed Entire exhaust system to RC40 exhaust with LCB manifold.
Changed all hard brake lines, except for the long one that goes to the back of the car.
Replaced headlights with new headlights
Replaced front seats with Corbeau Classic II seats
Installed rear seatbelts (lap belts)
Changed oil to Redline 15/50
Installed replica Inno Transmission Guard (aka Fireplace log holder)
Installed new headliner
Installed Newton Commercial Carpet kit
Re-covered parcel shelf
Installed 3rd brake light
Installed new front bumper
Installed Wipac fog lights
Painted valve cover
Replaced underhood lining
Replaced hood latch cable
Replaced hood latch
Replaced trunk seal
I've done more work on this car than on either of the other two....
FAQ Member # 2616
-- My wife.
Will I drive it! I think I'm going to drive it to work every day for awhile. And it's starting to get really hot here. But, after having it sit for so long, I'm dying to drive it.
Cool car pics. I love the Triumphs and the Sunbeam Tiger is sexy. The shop down the street from me was working on a Spitfire and this is the conversation I had with the mechanic:
"Cool car".
"Yep - but I wouldn't drive it down here. Get hit by a big truck or SUV, and you are dead".
And he's right. And the Mini is worse. But I'm STILL going to drive it....
I'll will my 2002 and all the parts to you Jim.
Ken
FAQ Member # 2616
-- My wife.
Ray -
No. The last cool seats you had were used as cat beds, until some dope bought them and had them shipped in the most convoluted way possible.
Hah!
Marshall -
I read a review of someone that did a Honda "B" engine swap into a mini. It was so powerful that it was almost undrivable.
I just need to drive it for a bit to see what her road manners are like. In 3-1/2 years, I've driven the car 4 times. Pathetic.
Ken
FAQ Member # 2616
-- My wife.
Marc on the faq board is doing an awd Mini in SoCal. Honda powered with 9 zillion hp. Marc of tha Taiga auto tii fame..
Yeah, now that you have the cat smell off the seats I want 'em back!
... You didn't go to Mid America, eh?
Cheers,
Ray
Ray
I like the seats. They are very comfortable - almost as comfortable as the Scheels I got from Ray. They are fixed back, but because of the way they mount in the mini, they sit very reclined. I ordered these with the inflatable lumbar support, but for some reason the driver's side doesn't hold air anymore. We'll see if that becomes a problem. They kick butt over the stock seats in this car - that's for sure.
I don't know if I would like them in my 2002 - but I'm 6'0 tall, and so I like a higher back seat.
FAQ Member # 2616
-- My wife.
Ken
Are those wheels "Rostyle" (something like that)? They look like MG wheels.
Where did you find tires for it? Most of the Mini's at the local show had Avon tires.
They are the stock "Rostyle " wheels. you get an "A" Jim.
I get made fun of by a lot of local car guys. It's a 10" wheel - it's an 8" rotor on the front!
Tires for 10" wheels are hard to come by. The ones on the car are KUHMO. When I get new ones, I'll probably go with Yokohama's
http://www.7ent.com/categories/wheels-and-tires/tires.html?sort=featured
Even though it was imported to the US in very limited numbers (mostly in the 60's), there is a huge mini following in the States. But - they aren't as cool as the 2002 crowd.
FAQ Member # 2616
-- My wife.
I RUN THE 10" KUMHO TIRES ON MY ISETTAS TOO .
I BOUGHT 3 EXTRA SETS WHEN THEY WENT OUT OF PRODUCTION AND SUPPLIES STARTED DRYING UP .
ONE SET WILL GO ON MY MESSERSCHMITT TG-500 PROJECT AND THE
REST WILL STAY IN STORAGE .
YOU CAN STILL GET A DECENT 10" FALKEN TIRE TOO .
