Trans mounts for a 5 speed conversion
algon
2 hours ago, Dionk said:
Had already happened once -huge chunk is missing from my input shaft. It was causing a leak- I cleaned it up and did my beat to mend the shaft- hopefully it won’t leak.
I placed the bolts in accordance with the little arrows.  Hmmm
Those arrows show the direction of the disc as it relates to the flange.
But what do I know
1 hour ago, mlytle said:
and cut the trans mount tabs for the 4spd off the tunnel.  makes things easier, gives more room, and you ain't ever gonna use them again.
Or- cut them off and re-weld them in pace for the 5 speed like I did. I bought the bracket relo kit with the bolt in tabs and then I realized I would have to remove those 4 speed tabs anyway. Why not reuse them for the factory look.
Having a welder makes fabrication easier.
But what do I know
