Euro Project D
ponchis
Oh it makes total sense, It just threw me off when I saw all those shiny brake components and then the stock pedal box haha, plus I just figured with all that cage fabrication a dash bar would make pedal mounting easy peasy. But in retrospect.. your planning on going sideways not stopping so it's not that big a deal. Let me know how you like that front brake setup, I'm looking into the wilwoods on my build.
  • Replies 70
  • Created
  • Last Reply
Top Posters In This Topic
several reasons for me including: I'm shaving my engine bay so the lack of all that stuff is a +, You can run twin MCs w/balance bar, you can get them in different pedal ratio's, I am running carbs via a throttle cable so they will be easier to mount a cable setup to. brake and clutch reverse swing mount setup is about $200 + your MCs
this is the one I am going to run with the dual ratio's : http://www.jegs.com/i/Wilwood/950/340-6451/10002/-1
woops forgot to update... today was kinda short but here ya go...
Made some space in the garage...
IMG_3928
Removed the fuel cell
IMG_3936
Time to get dirty! removing the subframes was pretty simple
IMG_3934
Out with the old and in with the new or restored
IMG_3932
Tii parts
IMG_3940
Because of this...
IMG_3946
I had to go with this... over kill? naaaahh
IMG_3941
Now i have this... some extra parts could come in handy...
IMG_3942
maybe try a welded diff to compare it with my lsd...
Thanks Bricklayer... The s14 is the correct engine since i cant really fit anything bigger without modifying the firewall.
GTI... Ive read that the earlier control arms were notorious for bending, even caused my potholes... So yep... Stiffer is better in this case
To my updates... Well i did take all my parts to the shop to start assembling. So i decided to put everything in the car without the bodywork... Why? Well i wanted to mock everything up first, start the car... Put it in gear... Turn it off and dissamble again... I dont want to drill any holes on fresh paint.
Tomorrow is a big day for mee... My package from RMS comes in! More power anyone???
Hey Tom... after i bought it, i asked myself... well will it even fit? too late but as i saw other s14 s/c'ed, then i thought it should be fine... i did some measuring and i think i maybe in the clear but theres always the alternative...
See how its a few inches off from the subframe? then a few inches for the subframe too...
IMG_4218
IMG_4219
Time for measuring
IMG_4221
IMG_4225
IMG_4227
Getting some help while i snap some shots
IMG_4228
Less than 3 inches from the subframe... i think i might be good
IMG_4230
IMG_4232
IMG_4233
IF all else fails, its time to cut... either way i was thinking of doing this for more tire/angle clearance... I cant cut passed the shock tower but everything else is fine...
LS in a miata?
motor-in1
damn really wanted to update but i forgot my camera... hahaha
well since i have a few pics saved... my front air dam is inspired by this challenger... simple and to the point
Not my photos***
1970_dodge_challenger_sam_posey
res20050101t1_p03
My flares are a bit different and i love the rivet/bolt look... thanks to the nissan skyline 2000gt
skyline_2000_gtr_1971
Looks like it's coming along great, really nice to finally see some pictures of this thing. In regards to the rear brakes, it is 1/1 (though I have one extra set of brackets as a "just in case"), still get a kick of how the rear disks ended up rather similar to Mike Essa's z4 rear setup.... http://www.motoiq.com/magazine_articles/id/1887/pageid/2876/hard-as-fck-mike-essas-bmw-z4-drift-monster.aspx
I just want to see this thing in action already.
Hey Andrew! Im glad i have a one off brake system. It looks very very similar to mikes. 2 bimmerfests ago i got to meet him and the z4. I really like his setup. Hes been doing well in formula drift too.
Yea my car was on a hold period but now is the time for everything to be installed! I have to take it to rms to get it tuned so maybe ill swing by to IE. i still need a few parts, like ur fiberglass bumper to cover those bars, maybe a few other things. Anything new i can use?
more parts n pictures!
I had a hard time deciding whether to go with red or black poly bushings and i came to the conclusion that theyll eventually turn black so why not rock them red while they last... hahha
IMG_4333
wanted to start building my front airdam so i welded something to grab it with...
IMG_4336
looks like ill have enough space... tow hook anyone?
IMG_4335
2 Packages came in today... rms and blunt
IMG_4356
M5 Crank hub and the S/C crank pulley
IMG_4360
made some mods to get more angle... stay tuned for the next visit!
