What tool should I use to remove this
Beck180
Trying to get this crimp off of my sunroof cords so I can put a new attachment on the end. I would then need to re-crimp it to hold the attachment on.
I have the Golde power sunroof so I can't just buy replacement cords.
Any suggestions on how to remove the crimp and them where to find a new one?
Thanks!
Beck
Hmm. One might be able to solder the old crimp back on, perhaps.
(I never had a sunroof '02).
GL,
Ray
Carefully cut through (split it) end to end with a Dremel/cutting wheel.
No clue about a new crimp though.
Ray
Don't bother.....If you've got a manual Sunroof...Go to pick a part and find an early 80's Volvo or VW and pull the cables. They are the same as the BMW ones....Its in a thread here somewhere.
DaveG
Thanks for all the suggestion everyone.
Sounds good. I've got a dremel so this should work.
Sounds very plausible. Someone off forum just suggested 3/16" brake pipe. Not sure what that is.
Would love to, but I have the early Golde power sunroof. Very rare as I have only met one other 02er who has one.
Thanks everyone!
