What do I need exactly to install my 5 speed conversion?
Guest djsekz
Guest djsekz
So what would i need to buy exactly too do my conversion from a 4 speed to the 5 speed? What parts are needed . need all specific details! thanks for all the helP!
What do you need exactly? First, you need to learn to use the forum search and site search functions located in the upper right corner of the page. The forum search is a bit quirky, but if you read all of the captions next to the buttons and dropdown fields, you'll be able to make some sense of it pretty quickly. The site search is pretty much a google search on the site.
After you've read the FAQ on the 5-speed conversion, and read a few members' threads on the issues they experienced, you can ask some educated questions about the particulars of your car and the transmission you've bought or are thinking of buying. As the member above noted, the 5-speed conversion FAQ is a great START, but it's not going to cover every nuance, every potential issue, all of the things you should be taking into consideration, or the solution for every possible problem that you could encounter during the swap.
williamggruff
www.2002parts.com sells an all.in one kit. Im buying.it as soon as money comes.
1971- 02-Malaga -(Ginger)- 2nd owner
1973-02- chamonix (sold)
pardon any grammatical errors in my posts, im probably on my cell phone.
Send it to:
2002 Haus, Rob Torres http://2002haus.com/
or
La Holla Independent, Carl Nelson http://www.bimmerdoc.com/
or
Casey Motorsports, Tom Jones, http://caseymotorsports.com/cms/Welcome.html
Andrew Wilson
