New Addition
fenstermaker
Bimmer has been in the shop for nearly 2 weeks with a fuel issue. Rebuilt carb didn't solve it. Runs fine when plugged into the shops gas tank, but mine causes it to run rough.
Could be the fuel line. Pump is running weak as well, though I installed a new one about 6 months ago.
Been in the market for a pick-up, so given the delays with getting my 2002 back, I went all out and picked up this thing... it's a beast.
Andy F.
'74 2002 Automatic
'79 El Camino
'07 Nissan Versa
Mount Vernon, WA
Hi,
this is a problem i have seen many times.
the fuel line is old in the trunk from the plastic
line to the tank sender. it allows very small
bubbles to get into the line and cause the car
to starve for fuel and run rough. replace the line
and make sure that the plastic sleeve on the
sender is in good condition or seal it with
some fuel proof permatex then install new
line and new clamps.
good luck
stone
stone racing co
phila pa 19123
That looks like my Aunt & Uncles neighborhood.
He has a blue '73 MG.
Andrew Wilson
