Recommended master brake cylinder replacement?
Sahara73
Hi,
Just purchased a 73 2002 and mechanic noticed a very small leak on the master brake cylinder(he is trusted and knows that I plan on getting dirty and performing the work myself) so my question to the forum is what would be a good replacement?
Looking at rockauto.com they show the following:
RAYBESTOS Part # MC39183 Professional Grade; Bore Size=13/16" Number of Ports=5 Primary Outlet Size=M10x1 for $158
CENTRIC Part # 13034000 for $144
ÜRO PARTS Part # 34311113656 for $84
A-1 CARDONE Part # 1139183 w/core charge for $84.
Thanks,
Jeff
I'll second that on Blunt. Just got one from him today and took about 1 1/2 hours to install and bleed. Stick with factory parts on this. ATE is the OEM on most BMW brake hydraulics.
Mike Katsoris CCA#13294
74 InkaGangster 4281862
76 Estorilblau 2740318
I was going to suggest, as you have a "small" leak, a repair kit.
However, it appears you have to take a mortgage for one of those now.
Try Autohausaz. com for an ATE (OEM) Brake Master Cylinder, currently on sale at $168 and free shipping.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
none of the above
order from any bmwdealer for a 2-Year/Unlimited Miles
parts warranty
or from member Blunt as noted above
you also need to inspect and plan on calipers, rear slave cylinders,
front calipers w/pads, all rubber brake hoses, cleaning,
measuring, lubricating, adjusting rear brake drums/shoes.
your going to flush the CLUTCH fluid at this same time
pedal box and pedal pivots need service, vacuum out all the
decades of crud under the floor mat, lubricate the pedal pivots
so all three move smoothly and return quickly
time to play catch up with all the neglected forgotten service details
don't get killed by ignorance - LOOK at everything
'64 R27 250cc #383851 18,000m
All parts are covered by their respective manufacturer's warranties. Although most warranties are for twelve (12) months or 12,000 miles, some manufacturers offer longer coverage.
this^
I'd second the ATE part... but honestly, the only manufacturer I have
less- than- oem faith in is URO- some of their stuff is pretty marginal.
  • 4 months later...
I'm wondering if you ended up going with one of these remanufactured master cylinders? If so, which one? Are you happy with the quality? I'm looking at brake calipers from each of these remanufacturers and am wondering what the exact differences are. Thanks.
