Strut spacer?
alpinems
I'm doing some cleaning up of the subframe and struts, getting ready to put my motor back in the car. This is the only '02 I know so I have nothing to compare it with. But from looking at some diagrams of stock struts, it looks like mine has some sort of spacer attached to the top of the strut.
Am I right? So anybody know why? Or can identify it? Thanks!
- Cris 70 Euro 02 - resto pages
Alpine Motorsports
http://alpinemotorsports.blogspot.com/
Not the resident expert and I'm sure others wil chime in. I believe the US versions had them as stock. To my knowledge they are not needed and most owners remove them.
Interesting as my car is an Euro, imported in the last 15-20 years. So somebody added them along the way.
Alpine Motorsports
remove that aluminum spacer and either use as
paper weight, or install on top of the inner fender
to take up the long exposed mount studs and act as a reinforcement
for the inner fender
important order of the washers!
'64 R27 250cc #383851 18,000m
Don't know why the spacers would have been on a Euro-spec car, as they were added on the US cars to raise the front end enough to get the headlights to meet the Federally-mandated headlight height. In order to bring the front end down a little and decrease the space between the fender lip and top of the front tire, most people have moved the alum. spacer up to the top of the fender (as c.d. mentioned) or removed them completely.
Bob Napier
Bob Napier
My guess is they were added when it was imported and they added all the useless stuff like the federated side and rear markers and reflectors, etc. They even removed the euro turn signals for US ones (shame!) When I bought the car somebody in the past has removed the front grilles and replaced with the black plastic ones from a later car - they were going for the turbo look.
Alpine Motorsports
These spacers (two different sizes) were fitted to all '02s, Euro & USA. Also fitted to E3 & E9 cars I believe.
The actual reason for them is still with the jury.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
Look carefully guys, the stud out of the top is not aligned with the head of the bolt from under the strut bearing flange. THOSE ARE THE NON ADJUSTABLE STYLE NEGITIVE CAMBER PLATES! Plus they are not thick enough to be the spacers they used on the US car for headlight height compliance.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Well spotted!
Les
FAQ Member #17
Well I'm glad I asked after all! Thanks for the closer look.
Alpine Motorsports
