The view from underneath
Funny that my comment was to be that you need some new rubber here and there...I thought my 02 was a little bit twitchy with poly (I don't do track time), and happily went back to rubber...I guess that is what makes horse races.
Your pictures are the type that everyone buying a car would love to see. Some bushings, a little rocker rust, but pretty honest. (Yep, I'd buy it!)
Enjoy your dad's old toy.
Dave V. in NC
I guess we figured out what that noise was in the rear...looks pretty good, better than most, easy fixes.
From experience, i suggest you take a good look at the front ball joints. Otherwise you might get to share my experience. Fortunately only going 10 mph when the left front ball joint separated. Probably would have turned into a flaming orange ball at any faster rate.
1974 Inka 1802 Touring, New Daily Driver
1976 Inka 2002 Original Owner (adopted by Scott B.)
My Roundies are bigger than yours
Your car looks really good.
What is that photo of that is sort of gray and has the writing on it. E6 Touring?
That is the muffler. My guess it was replaced in the late 70s when the car was rear ended. My dad must have found an original one? Looks to be dated 09/76
Ben in Denver
2000 Touring INKA 3357390
That is neat. Last I heard the touring muffler is NLA.
Do you have a rubber thing covering the hinges in between the backs of the rear seats? I have never seen a touring with that piece.
1972 2000tii Touring #3422489
FAQ member #5
I wondered that too, I am betting on a replacement sport muffler, MFG in 9/76. Leistritz made sport mufflers in Germany.
I know that view all too well... I've been under that lift a few times myself. You're in good hands. Mark did great work on my '02. When you get it back let us Denverites know and we can get together for that first fun run. Way cool car. RR2
RipR2
The BMW 2002 US VIN 2591740 was manufactured on June 4th, 1973 and delivered on September 14th, 1973 to the BMW importer Hoffman Motors Corp. in New York City. The original colour was Fjord metallic, paint code 037.
DO NOT REPAIR the gear box or diff oil seepage!
it's the cars automatic rust preventative option. Really.
....just drain and refill
DO FIX the leaking exhaust manifold studs
Patch the small hole in the rocker panel.
Replace all anti-sway bar bushings with urethane
and new long bolts & nuts
Replace front thrust radius rod bushings
Replace both bolts with bushings and spacers-
on the trans/exhaust support bracket
now your good to go ,
nice Touring.
'64 R27 250cc #383851 18,000m
I've got a set of poly sway bar bushing that had less than 500 miles on them when I pulled them off my car. I'll send them to you for the price of shipping if you'll put them on that car.
'71 02 - parts car with not many parts left
'73 02 - weekend toy and money pit
'74 04 - sold in '91
'03 325iT - for trips and bad weather
'03 50cc Honda Scooter - for my 2 mile commute
'06 50cc Honda scooter - wife's commuter
Nice road-side shots.
I noticed your left control arm is bent like something had come into contact with it.
Also:
Wonder if that block heater still works!
Original riveted ball joints (mine were just replaced on the 73tii).
Welded exhaust system (no clamps)
Old flexible brake fluid hoses (safety 1st)
Squirrel gnawed sway bar bushings?
When you get the chance, pressure wash the underside. Makes working on it much nicer.
