suspension springs
71bmr02
what I contributed many moons a go :
stock / oem 02 suspension coil spring colour codes and free length (not mounted length);
REAR SUSP SPRINGS
Green 776-803 lbs
White 750-776 lbs
Red 725-750 lbs
wire thickness 12.3mm (.049")free length unmounted 334.6 (13.17")
Heavy duty conversion ( for trailer towing )
grey/green 769-789 lbs
grey/white 730-769 lbs
grey/red 710-730 lbs
wire thickness 13.2mm (.052") free length of unmounted 324.2mm (12.76")
FOR touring - USE ONLY RED (in emergency WHITE is permissable
always use "1 Dot " rubber top cushion
FRONT SUSP SPRINGS
green/blue 635-656 lbs
white/blue 614-636 lbs
red/blue 595-614 lbs
wire thickness 11.8mm (0.465") free length unmounted 337.2mm (13.28")
Heavy duty conversion (only if rear is also converted)
green/grey/green 606/626 lbs
white/grey/white 584-606 lbs
red/grey/red 564-584 lbs
wire thickness 12mm (0.47") free length unmounted 345mm (13.58")
..........SO, AS YOU CAN SEE , WHEN INSPECTING UNKNOWN SPRINGS, THE FREE LENGTH CAN BE CLOSE, BUT IT'S THE WIRE THICKNESS THAT YOU NEED TO MEASURE CAREFULLY
THIS REF. FROM BMW REPAIR MANUAL (PRINTED) VOL.2
and. . . ..
rear coil spring upper rubber 'damper ring' comes in 3 heights:
28 mm height = 1 dot and green color code
33 mm height = 2 dot and white color code
37 mm height = 3 dot and red color code
Note: always fit top spring damper with 1 dot for Touring models (of course for orig springs)
check availability with dealer, one was NLA reciently.
the bottom rear coil spring rubber damper ring comes only in one thickness = 24mm
ref. 33-0/8 specifations BMW Repair Manual Vol. 2
AND........
SPRING TIME TECHNICAL DATA:
Message Title: Re: front or back?
10 1/4 " = Front
12 " = Rear
these are my 'old' Suspension Technique (dark GOLD painted) springs
measured "free" un-mounted length
and from factory manual:
13.28" = Front std
13.58" = Front Heavy Duty
13.17" Rear std.
14.25" Rear for Baur Convertible
...so according to this info, you could have shorter or longer springs in the rear than front ! What matters is wire diameter and lb. rating / spring load rating. So difficult to say with out knowing any part numbers or spring mfg. which of you springs belongs where. How about buying a new set of H&R 's which are clearly marked and you'll have a'fresh' set on the car. Throw some new BILSTEINS on while your at it.
'64 R27 250cc #383851 18,000m
sorry didn't mean to step on your earlier message. Really good thorough info in your latest message however. BMW stock spings must have been made from the best materials available. My stock springs on the 71 have .465 wire and free length of 13.1 inches. of course the diameter wouldnt change but the free length could change if meterial is less than best they could get. still 13.1 inches after all these years is a testament to BMW quality.
G
Gale H.
71 2002 daily driver
70 2002 malaga (pc)
83 320i (pc)
