WTB: oil pressure sender adapter-Resolved
Guest_anonymous
The adapter that allows installation of the VDO oil pressure sender for an oil pressure gauge (m10 x 1.0 threads) into a distributor housing cover (m12 x 1.5).
TIA Daron
Thx Jim, for some reason I wasn't thinking that way. Emrick and Hill is right around the corner from me at work also not far from Fluid Power Tech. I'll check there. ? Bav auto sells a piece that angles to the side held into the distributor housing with a banjo bolt, and not just a thread adapter, I'm assuming this is for distributor clearance for the sender? Do you suggest that these types of hydraulic supply would have this?
  • 3 weeks later...
Thanks Jim. Since I had some time, I procured a distributor housing cover with the M10 x 1.0 thread for the sender.
Daron
