New 12 volt Battery , weighs just 3 pounds .
LimeySteve
Looks great weight savings is great specially for track cars. As long as they are not the same manufacturer that does the ones on the 787 we should be fine haha. Had to say it...
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
  • Replies 33
  • Created
  • Last Reply
Top Posters In This Topic
li ion or li poly require special charging devices
yeah, they do, emphatically. Like, burning 787, they do.
So if there's an equalizing circuit in there with protection, then they're safe
for cars... mostly.
If there's not, they'll do the amazing Sony laptop flambe.
There must be.
The model flying community uses unregulated cells, and there's quite a bit
of attention paid to keeping them safe.
Because they can be quite dangerous if not taken care of properly
(as in, better than an alternator does for a lead- acid)
^that is very,very true.I watched a truck almost burn to the ground after a guy hooked a li-poly model airplane battery up to the charger connected to his truck battery. If the cells get just slightly damaged/overdischarged/overcharged, they are very unstable.
Well I am going to be the guinea pig & fit one to my car tomorrow , hopefully it won't go like a bomb :) Under the hood , I did get the plastic covers & they fit perfectly.Time will tell , I have a single wire alternator .
1970 4 speed 2002 (Daily driver/track car )
1974  Hybrid powered twin cam engine, Pig Cheeks , ( now a round tail.) Getting ready to Sell
What are the manufacturer's published instructions? If none, I'd stay 30 feet away and certainly not risk having it burn my non-replaceable car. If the mfr's inctructions are not followed, the user is on his own.
Well I am going to be the guinea pig & fit one to my car tomorrow , hopefully it won't go like a bomb :) Under the hood , I did get the plastic covers & they fit perfectly.Time will tell , I have a single wire alternator .[/quote
steve if they work on bikes iam sure all is okay,I only have limited experience with li-ion,li-poly 30c discharge rates for toy airplanes.If they push these on 2 wheels, then sign me up after your beta test.
I've seen lithium ion batteries overcharge with terrible results on motorcycles. Granted, this was when the technology was fairly new years ago, but as with any new product, I'd like to see proof of the reliability as well as proper instructions from the manufacturer (or at least a guide stating "what not to do" )
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
Some manufacturers have electronics built in to prevent the under and over charging idiosyncrasies of these… does this battery have that? I don’t see it mentioned on the website. Maybe that’s why this is a comparatively cheap Li for it's fairly high capacity.
AGM’s seem to have this similar intolerance to under/over charging only without such violent results. Most of the problems I’ve seen in the forums about these look like misapplications to me… too small capacity for the car.
Yes please, post updates periodically. I’ll be looking at this for my EFI conversion to avoid running battery to trunk/seat. Right now I have my eyes set on the Braille B2618 AGM battery (8.1”x3.5”x6.3”, 18lbs, 475CCA, 27AH, RC=35min, $210) which looks like it may allow me to fit the EFI air filter above the battery, as you can see it too is only 3.5” wide. Maybe this Mirai would give me another option minus several more pounds to boot.
OT - I have also been researching a battery replacement for my mustang that is getting some mods this month. Since I’m in the market for a battery NOW I have decided on the Braille B3121 (6.6”x5.2”x6.8”, 21lbs, 550CCA, 31AH, RC=75min, $180).
Rob
1966 Mustang vert - 5.0EFI/AOD & mods
1975 '02 - the typical upgrades (my 'new' car)
Here is the answer I received from them today .
Make of it what you will I'm fitting one tomorrow.
Hi Steve,
Regarding overcharge protection, most of the products out there do not
have a true overcharge protection system, it's a gimmick more than
anything else.
There are two types of "BMS" systems out there used in practice where
companies claim they have overcharge protection, 1. is simply a cell
balancer which shouldn't be called a BMS at all, the other 2. is an
actual BMS that has all the protection circuitry for over/under voltage,
over/under current, etc.
1. Most companies that claim to use a BMS simply use a cell balancer,
which just puts the charge from the cell with the highest voltage to the
one with the lowest voltage until they reach equilibrium. It doesn't do
anything to protect the batteries and usually they constantly place a
load on the battery, so they do affect the shelf life of the battery
pack. If there is one bad cell in the pack to begin with, the cell
balancer will constantly be trying to charge that bad cell so ultimately
it will wear out the life of the pack sooner as well. The amount of
current that it moves from one cell to the other is also very small so
in practice, it just provides a false sense of safety since it doesn't
protect the battery at all.
This is like the system on EarthX, they claim overcharge protection, but
if you look at their manual, it can't protect an input voltage over 15v.
If you have a bad alternator, it can not only exceed 15v, but it can do
so at a very high current, that will destroy BMS PCB immediately. The
LiFePO4 cells are able to absorb higher voltages for short periods of
time without any circuitry, they have to be able to withstand 5.5v per
cell for over an hour without causing a fire or exploding to pass safety
standards, they will vent and smoke, but again, this type of circuitry
will not do anything to prevent that.
2. The second type is very rarely used in the industry as the costs are
prohibitive in this type of application. A true BMS should have
protection from over/under voltage and over/under current, but the
amount of current drawn during start-up could be several hundred amps,
no consumer grade PCB can withstand that. You can get an idea of how
much this would cost by heading to the following link. A 100amp BMS for
a 4 cell system is priced at $138.95, a 500amp system which would be
necessary on our model with 450CCA would cost 5 times as much and
require a substantially larger footprint. Keep in mind what gauge wire
you would need for 500amps, clearly PCBs will have a hard time dealing
with just the heat generated from a 500amp load.
http://www.batteryspace.com/pcmforlifepo4packs.aspx
Again, we've tried both methods during the course of development of our
batteries, and neither provided a good system. The better solution was
to use better cells in the first place and have them impedence matched.
LiFePO4 cells do not require as strict cell balancing as standard LiCoO2
and LiMnCoO2 cells do, it isn't easy to get an LiFePO4 cell to combust.
Granted, it can if you short it long enough or put it under a load
greater than it is designed for, but in such circumstances, any battery,
lead acid included, will cause a safety hazard just due to the sheer
amount of energy involved.
Hope you find this helpful. Please let me know if you have further
questions. Thank you and have a great weekend!
This convinces me thoroughly that a lead- acid battery is still the
best answer for all of my cars. LiFe for the laptop, LiPo for the planes.
I'll save those 15 lbs somewhere else, thanks very much.
This exactly. Yes, using "better cells" (whatever that means) and having them impedence matched is a good idea, but it does not mean that it is safe. Them stating that the other manufacturers overcharge circuitry "doesn't really work" is just a defense for them not having one. I have seen friends lose 10,000 dollar bikes thanks to overcharged batteries igniting and the fire spreading to the gas tank which isn't far away. Whatever BMS certain guys like AGM use, it works. Once the batteries were a bit more developed and the bugs sorted, the number of fires decreased significantly.
Now this is all on a motorcycle with a relatively small charge output compared to our cars. The bit where they said
"A true BMS should have
with just the heat generated from a 500amp load. "
is just bullshit. a 500 amp BMS shouldn't cost significantly more then a 100amp BMS... anyone with a basic understanding of electrical engineering and production should know that. Heck... the least they could do is incorporate an overcharge protection circuit that consists of a breaker just in case charge amperage is too high or voltage spikes for whatever reason... them having none is just asking for trouble.
A bunch of Bikes...
OK The test begins , I do listen & read so I took the precaution of putting the battery in a box, I had an ammo box that the battery fitted perfectly so I made that into the hopefully ballistic battery box. I used the foam they include in the packaging to insulate the lid & in it went. Time will tell on the performance. I tested my charging & it is 14.3 volts max .
