1975 Bmw 2002
1975 BMW 2002
Black on Black, with factory sunroof
Original Paint (two small rust areas now coming through)
320i 5-speed transmission Conversion
Recarro Seats
Performance Sway Bars with new Poly Bushings
38/38 DGAS Weber Carburator
Stahl Header (removed emissions)
New Bilstein Front and Rear Shocks
BBS Factory Alloys
Hella H-4 Headlights
New Windshield, Door, Rear quarter Windows, and Trunk Seals
Electronic Fuel Pump
Pedal Box Rebuild
Speedo Rebuild
Tach Cluster Replacement/Rebuild
Tii Clock (needs service)
Oversize 320i radiator
New Ignition/Steering Lock Assembly
Performance Brake Pads/Shoes
Stainless Steel Brake Lines
Rear Brake Rotors
Master Brake Cylinder
Windshield Washer Pump
Rebuilt Heater Box, New Fan/Bushings
Center/Rear Muffler, and Exhaust System
New Starter
Powder-Coated Valve Cover
Clutch Master Cylinder
Headliner Material
Tie Rod Assemblies
Wheel Cylinders
Bridgestone Potenza RE960AS Pole Pos 195/60R14
Complete Engine Rebuild (essentially to blueprint)
Winter 2010-11, +/- 2,500 miles since
Surface/Grind all machined surfaces (crank, valve seats, head, etc)
Cylinder bore to 3.526
Compression Ratio 4.5:1
Arias Custom Pistons
Performance Ring Set (1.2/1.2/4.0)
Cometics Multi-layer Metal Gasket Set
Rod Bearings
Main Bearings
Tensioner, Chain, Gear
Cam Gear
Valve Springs (ITM)
Oversize Stainless Steel Intake and Exhaust Valves
Cam regrind/core to 440 lift
Bronze Valve Guides
Cometics Rockers, Rocker Shafts
Reconditioned Rods
Surfaced Flywheel
Custom Port Work
ARP Head Studs
Dynamic Balance
Near-Compete Receipt set
Needs
Body/Paint
Carpet
Door Brakes/Adjustment
Window Adjustment
Dash
Contact
Kenton Wiens
kenton.dialog@gmail.com
503.516.8182
Year: 1975
Make: BMW
Model: 2002
