87 Bmw 325Is E30
gargtat
1987 BMW 325is 5spd, 197k miles. These are becoming hard to find, I have only seen 2 on ebay and they both sold before the auction ended. NADA on these are Fair $3500, good $4500, excellent $6500. I purchased this car with the intent of using it while I built up my 2002 daily driver but plans have changed. I have a blue title for the car, it is not in my name but it is signed over.
This is the work that has been done on the car:
New:
timing belt
timing belt tensioner
water pump
Clutch
Throwout bearing
muffler
radiator
Guibo (driveshaft flex) joint
Driveshaft carrier bearing
Transmission has also been replaced and shifter repaired
3 of the 16" wheels on the car are an unidentified brand but 1 is a voxx
which should be easy to match
The leather interior is better than most but does have some cracks
The AC needs a recharge but has been converted to 134a in the past
The front spoiler is damaged and I was going to repair but it is original and would best be left to a professional to be done correctly so I left it alone
The brakes, suspension, and steering are all in good shape
No tags and no inspection so it will need to be towed or registered before it leaves.
If you have any other questions just ask $2400 obo if you want more pics, I have plenty. or any other quesitons eurorpm@gmail.com
Year: 1987
Make: BMW
Model: 325is
Body and Interior: Good condition for its age
Engine and Drivetrain: TB and WP just done, all other in good shape
Suspension, Brakes: All are good, brake pad light is on but all pads check out OK
