Renewing Rear Wheel Bearings
Buckeye
Spray castle nuts  with penetrating oil several times over a course of a few days and let it to break loose surface tension rust and corrosion.
Jack up and support vehicle
Remove tire
Remove cotter pin
Replace tire and lower car to ground
Apply parking brake and car in Neutral
Loosen up castle nut with 36mm socket and long handlebar
Jack up and support vehicle again and release parking brake
Remove tire, castle nut and drum brake
Heat hub for about 15 minutes. Rotate hub as your heating it.
Pull off driving flange/hub with extractor
Detach output shaft / CV shaft from axle shaft and tie it up
Screw on castle nut with notches facing brakes, then use soft hammer to drive axle shaft out
post-43112-0-11927400-1382783644_thumb.j
post-43112-0-98371300-1382783685_thumb.j
Outboard
post-43112-0-17168300-1382783772_thumb.j
Inboard
post-43112-0-26619700-1382783800_thumb.j
Pry out inboard and outboard sealing rings. From inboard side drive out outboard bearing with soft punch (brass) and hammer. Now shim ring (if any) and spacer sleeve can be removed from outboard side. Now can easily remove inboard ball bearing with punch and hammer. It is imperative that circular shim and spacer sleeve for each wheel kept separate if rear wheels bearings removal done at once.
post-43112-0-32097400-1382783965_thumb.j
post-43112-0-46155500-1382783982_thumb.j
Wipe inside with paper towels and spray inside with brake cleaner.
post-43112-0-21500200-1382784189_thumb.j
post-43112-0-74561500-1382784224_thumb.p
New bearings and seals
post-43112-0-22081300-1382784317_thumb.j
post-43112-0-66780700-1382784335_thumb.j
post-43112-0-96315300-1382784351_thumb.j
post-43112-0-76096600-1382784412_thumb.j
Next, Pack bearings with grease and grease sealing rings lip
Install inboard bearing. I used 1-1/2” dia. PVC coupling and plug to drive bearing in against bearing bore stop.
post-43112-0-13060800-1382784670_thumb.j
post-43112-0-97843400-1382784692_thumb.j
Coat sleeve spacer outside with 35 grams grease and then insert sleeve to the cavity from outboard.
post-43112-0-51567400-1382784849_thumb.j
post-43112-0-61304100-1382784874_thumb.j
Insert shim ring then, install outboard bearing making sure it is seating against shim
post-43112-0-77813900-1382784971_thumb.j
post-43112-0-25071500-1382784995_thumb.j
Install inboard and outboard seals
Insert axle shaft from inboard side all the way in
Install hub/ driving flange. May need to use hammer on face of hub to seat it in
Tighten castle nut with 36mm socket
Replace drum brake
Install tire and lug nuts
Put rear wheels on ground
Apply hand brake
Secure front and back of rear tire with objects to prevent it from rotational movement
Tighten castle nut to specified torque
post-43112-0-77113000-1382785066_thumb.j
And for last time Jack up and support vehicle
Remove tire
Install cotter pin and bend tabs
Put tire back on and tighten lug nuts
Lower the car and torque lug nuts to 65 ft-lb
This post has been promoted to an article
76 2002 Sienabraun
2015 BMW F10
There used to be a section of "FAQs Under Construction" where good write-ups like this are posted.
I think it is now called ARTICLES. Look above. May want to consider posting this nice article there too.
Edited by BillWilliams
1972 2000tii Touring #3422489
FAQ member #5
Buckeye - Thanks for documenting (with photos!) how this is done and now I know what 35 grams of grease looks like!!!
PS. I copy and paste this type of info into a Word document stored on my local hard drive.  So if/when the "web gremlins" strike I'll have it to put back up for all us FAQers.  TR
'71 MGB - sold   '74 2002 - sold
'89 XR4Ti - sold  '94 Miata R Package - sold
'73 tii - restoration project - sold
Never knew the 35 grams part was important. Interesting! Good write up! Hopefully I'll be doing this this winter.
-Nathan
Yes, the grease is quite important-
if you do the domestic version, and just
grease the bearings, they spit it out and run dry.
Same's true in the front.  When the hubs get truly hot,
the grease reflows and while it may get pumped out of
the bearings, when you stop, it reloads the bearing.
Nice write- up!  I'd add an 'inspection' step where you look
for wear on the inside of the stub and on the center spacer...
I usually on all my hubs I do (I do a lot of trailers) just fill the centers till it looks right. Never a prescribed amount. Many of the trailers I work on have zercs on the spindle end so you can pump them full from back to front. Nice idea actually!
-Nathan
instead of "copy and paste", just do "options/save page as"  in whatever browser you use.  that way you get the whole page and all the buttons/links work next time you open it.  i have many folders full of saved pages.
2xM3
  • 8 months later...
Great directions! This note is working on my 1972 2002. I would like to add a lack of knowledge mistake I made. When disconnecting the CV joint from the flange, push the hex bolts only far enough for the axle/CV joint to be moved out of the way.. I pulled them complelely out, lack of knowledge or common sense!  Result, the CV boot came off and getting it back on was a learning experience I do not want to repeat..Tip, if it does come off, jack up the wheel assembly so the boot can go on almost straight across. Easier to attach the clamp that secures the outside edge. Hope this saves someone time and labor. Again, great article and the other rear bearing was installed no problem.
  • 3 years later...
Great article, just wondering why I shouldn't use a SKF 62/28 sealed bearing? The grease was a real pile on disassembly + 35 grams going back in . . . yikes. I'm doing this service just because I'm media blasting all the sub frame bits.
