Weber 32/36
_iwanta2002_
I would try running it before rebuilding it. If fuel wasn't in the carb it should work. Might leak a bit depending how long it sat but no harm in trying to run before doing work.
Rebuild kits are easily available, it's a very easy carb to rebuild
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
When set up properly the water choke works very well and requires no real input from the driver to use (aside from depressing the accelerator once to the bottom in order to turn it on). Electric and manual chokes look a bit cleaner though as they require less plumbing.
A bunch of Bikes...
I've had better luck with the electric choke, for whatever reasons.
Get a kit, pop the top, and change the rubber bits and needle valve.  It's not really a 'rebuild' but it's
good for 95% of what ails a Weber.
Check the float for gas in it, set the level, read the numbers off the jets and write them down,
and off you go!  Almost guaranteed!
I had no history on my 32/36 when I bought the car. I never touched it except for looking down the throat to make sure everything was working right. I have driven it two driving seasons now without incident. I figure if it ain't broke, don't fix it. At least until I run out of things to do.
I have the water choke and it works great. I give two pumps on the gas before I start it to close the choke and squirt a little fuel in. The choke then opens up as the water temperature warms up. Never have to think about it.
I had a car that sat for a while and I really didn't have trouble with the Weber but I did get into a lot of trouble for not drain the old gas out of the fuel tank. The fuel was contaminated and dirty and it plugged everything thing up and I had a lot of work getting that mess cleaned up. So think about draining the old fuel out and cleaning the filter in the tank. Add fresh premium gas and see what happens.
I've survived damn near everything.
1974 - 2002, Mild - sold to son
1976 - 2002, lil' Wild
Thanks guys. I won't get around to the carb until tomorrow and at that point I will provide some feedback. Willie, I've already cleaned the fuel tank which was filthy, as expected. Thanks for the heads up. Did you encounter any gasket around the pump in the tank? Kind of looks like an O ring?
  • 4 weeks later...
I have this same two-barrel carb on my '73, but I don't know much about it.  How do they work?  Does the car run on one barrel up to a certain speed, and then the second barrel opens?  Or do the barrels feed different cylinders and all open together?
Phil B
I am learning about these carbs myself, but in observing the motion of the linkage and flaps it is clear that one barrel opens first (the smaller one as I recall, presumably the "32" in the name) and then if you really step on it the larger barrel opens as well.
Edited by glemon
Lincoln, NE
74 2002
68 Triumph TR250
