Fuel Sender Unit Sleeve
goodbyecharlie
Hi All, I'm having problems with a fuel leak.  Gas is leak around the fuel sender unit's outlet.  I am missing the sleeve that would normally go around the metal outlet and into the rubber hose.  I'm pretty sure this is the problem.  Can anyone tell me a good repair for this without having to buy a new one online and paying double for shipping?
I read the c.d.iesel's post about putting an 8x13 hose around the metal outlet.  http://www.bmw2002faq.com/topic/144143-cracked-fuel-sender-sleeve/?hl=fuel+sender+sleeve#entry941430. Has anyone tried this, or can tell me that this will definitely stop gas from seeping back from the hose?  Also if i do this option, will this hose also go directly to the hard plastic fuel line? How would I seal this hose to the hard line? My intermittent cloth rubber hose that previously connected the metal outlet to the hard plastic line isn't a good seal right now.
Thanks in advance.
