8X13Mm Fule Line Substitute
CRMonty
74 02Tii
Middle of Restoration
3/8 hose does not easily fit the fuel pump coming from tank. I was not able to get a larger hose thru the hole in the trunk.( I can get the 3/8 hose on.)
Is there a new metric fuel line that may work?
74 Tii
79 CJ7
58 Cushman Eagle
Just found at Rogers Tii. I have found most of correct part local but not the metric hose. Thanks
74 Tii
79 CJ7
58 Cushman Eagle
jgerock,
not that I've changed that hose a zillion times, but I've never had that much effort necessary to slide the hose through that hole.
I am now curious as to the outside diameter of the hose you show in that picture.
AND I need to crawl underneath and verify what hose I actually installed ..... hmmmm.
Cheers,
Carl
jgerock,
Cheers,
Carl
IIRC - the new hose is 12mm I.D. x 18mm O.D. so the factory pipe in the body is a tight fit with new hose.  I have since changed my factory tii fuel pump to the in-tank E30 unit.
