Separating Hub & Caliper
Dutchie3719
Go to solution Solved by tim385,
I can't seem to separate the hub and caliper to replace the press fit wheel studs. I've tried heat, and air tools, but all the hex key bolts are pretty damn stuck. It's not like they're very rusty either, I'm betting they got over-torqued before I got my grubby paws on the car. Any trick to separating them? Anyone know torque spec for these bolts?
While I'm at it, any tips on press fitting the new studs in?
-Dan
Daniel Shor
Bethesda, MD
'74 2002 "Charlotte"
Half as old as my first car and I wouldn't have it any other way.
So you have not been able to get the allen bolts out that hold the hub and rotor together? I got mine apart a couple days ago with no too many issues.
I don't know if it really works or not but giving the bolts a good whack has helped me with stuck bolts in the past. A little of that, some PB blaster, some heat (be careful of the fumes). I do it several times applying force gradually.
Good luck!
Presume you mean the hub and rotor, not caliper.  If so, and if the allen bolts are really stuck, I'd remove the hub/rotor assembly from the car and use heat on the allen bolts that hold the two together. Much safer than heating 'em on the car, as the grease around the wheel bearings can melt/catch fire, and you might ruin the wheel bearing grease seal and not know it.
Be careful forcing the allen bolts--you really don't want to either break 'em or round 'em off; in their recessed position they will be a real PITA to remove if either happens.  Heat, penetrating oil and patience are your friends.
Once you have the bolts out, a few whangs with a hammer (dead blow if you have one, otherwise a heft ball pein) will separate hub and rotor.  Before you reassemble, I'd coat the hub/rotor mating surfaces with anti-seize compound, and also put some on the allen bolt threads.  That'll prevent future trauma...
cheers
Make sure you're using an in-hex socket.  I have reverted to a rattle gun in past-
those things really like to bind in there.  Wear safety glasses.
And this is probably the #1 reason I go to vented brakes in front.  Well, that and the warping
DOH! Hub and Rotor.
They are off car. Broken Stud, and sqeaky wheel bearing...
Beyond Heat and Really Really Long Bars there's nothing I'm missing eh?
Daniel Shor
Bethesda, MD
Cussing
+1 on this
++2 on cussing in German, maybe c.d. has a language converter in his stash
Happy Trails to u~ Dave Miller
76 Golf~Rhiannon~BM Mascot~*~97 328is~Silver Ghost~*~68 1600~Wisperin Beast~*~70-02~Bumble Beast~*~76 02~Beast~
Keep smilin all the way
I put it in a vise with tubes around the stud threads. Others bolt it to a rim and tire to hold it steady. PB blaster soak, heat, I've used the impact gun on a low setting. If you do it by hand, like any rusty bolt, the trick is to go slowly, and every few turns out, wind it back in and start again. That tends to avoid a build=up of crud on the threads that can bind and snap a bolt.
+1 on this
No cussing in german. It´s "küssen" with two dots above the "u". ;)
Best regards, Lars.
Edited by LarsAlpina
Ei guude wie? (Spoken as "I gooooda weee" and hessian idiom for "Hi, how are you?")
Já nevím, možná zítra.
  • 3 weeks later...
We're talking about crazy nuts are we... I had a bear of a time getting my strut gland nuts off >.<
-Nathan
