Corroded Alt/reg D- Wire
worzella
I am cleaning and re-taping all of my wiring looms on my '75 and all was going well until I unwrapped the big bundle that includes the alternator to voltage regulator wires. This is the bundle that drops down from the alternator/starter and then across over to the inside fender wall up to voltage regulator.
Anyway, all the wires were in great shape except for the D- lead from the alternator to the voltage regulator.
It literally crumbled in my hands... the wire covering was split and falling away and the wire itself was brittle as hell.
The wire condition got a bit better within about 5 inches of the alternator plug (D-, DF and D+) but on the voltage regulator side I noticed a wire splice just before the voltage regulator connector.
So something must have been going on with the previous owner(s) and a patch was made at one point.
Thanks
1975 - 2366762 Born 7/75
See the whole restoration at:
That's a ground wire and is not used to carry any high current. Simply replace it with #14 wire. The original color was brown, as are all other ground wires on that car. Make sure that you also have another short piece of fat wire going from the alternator housing to the engine block.
Edited by allbim
Too many cars.
