Brakes
Desiderio
Just replaced my rear brake cylinders.
Recommend spraying wheel cyl. Bolts and brake line nut, as well as brake adjusters the day before starting. Buy new bolts for the wheel cylinders also as some of mine broke off. Used PB Blaster, worked great. Bolts are 10 mm heads and the brake line is 11mm. Use a flare nut wrench for the brake line. Have a few cans of brake cleaner to clean the backing plate , return springs , ECT ...
