Rotor Hex Bit Size Question
Napes
I think you're good. I wanna say it's an 8mm...
-Nathan
8mm seems to ring a bell with me too...I know that's what E30s use to hold their rotors in place, and it would make sense that BMW would have used the same size screws for a similar job.
The best thing is to use an 3/8 drive impact driver (the kind you hit with a hammer) with your 8mm Allen bit to loosen them instead of taking a chance on stripping them with a regular Allen key. Clean the holes out good with a little oil and make sure your Allen bit is firmly seated before you try to loosen. I like to tap mine in with a hammer to make sure I have a good bite.
Mike Katsoris CCA#13294
74 InkaGangster 4281862
76 Estorilblau 2740318
Thx for the tips, Guys.  For Hans:  I use either Wurth Rost Off or Kano Laboratories AeroKroil, both of which have been shown in tests to be far superior to PB Blaster.  I will clean out the holes real well (as I do with the Fillister heads on the half-shafts) and might try easy hits with the air impact wrench.
Bob Napier
Bob Napier
This is always interesting:  http://www.garagejournal.com/forum/archive/index.php/t-200247.html
Ray
I wouldn't use an air impact wrench.  It might be too powerful and it isn't the same as the hammer driven one.  With every hit of the hammer you are driving the bit in and turning it at the same time. It won't slip.   An air impact gun is only twisting it and if it isn't seated properly or straight you will strip it real quick.
I rattle- gun the suckers all the time.  But I DO tap in the bit with a hammer, and sit on it to get it to break loose.
While wearing safety glasses, of course.
The real stinkers are the 6mm rear CV bolts- those really want to strip out...
Yeah, but aren't those not recessed? So you could, perhaps, grab them with vise grips as required?
They are indeed tougher than the front CV bolts.
:P
Ray
