Tii Throttle Linkage Lubrication
Ringworm02
Last time I rebuilt the linkage on my '73 I used Mobile 1 synthetic grease.  Also have used TriFlow drip oil to lube the throttle body shaft.
Edited by JohnS
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
Use a dab of grease on each ball and socket. Does not have to be some exotic EP grease, regular wheel bearing grease is perfectly OK, it is designed for much higher pressure than any throttle linkage will ever see.
Chris A.
---'73 BMW 2002tii road rally car, '86 Porsche 944 Turbo track rat, '90 Porsche 944S2 Cab daily/touring car, '81 Alfa Romeo GTV6 GT car/Copart special, '99 BMW Z3 Coupe daily driver/dog car, '74 Jensen-Healey roadster
---other stuff
I gave up lubing those things decades ago ..... so far, so good ......
Cheers,
Carl
It's a good idea to put a bit of grease on there if you have them apart, the ball sockets DO wear. I just replaced the linkage piece between the two bellcranks on mine for this very reason, and throttle response was improved.
 But, it is not necessarily a normal maintenance item, the grease should stay there for a long while . . . .
Edited by cda951
Chris A.
---other stuff
