1972 Tii Rear Bumper Center -Help-Where Can I Find It?
I am quite frustrated with trying to get the center section and the clueless parts supplier. I ordered the center section part # ending with 006 and the cross section was too big. The part supplier then proceeded to order it from in-country and then from Germany with the same part number expecting different results, (see photo, plastic wrapped one is the new one). I then asked them if they thought maybe it was the European version, they then ordered that part, #656. He sent photos that showed that the ends were the right ones, but I was concerned that the section may have the licence lights holes. He really couldn't answer if they did. Thus, if you are still with me: What part do I need to order to get that center section of the rear bumper?? Is it NLA?
post-40174-0-38844700-1404769515_thumb.j
post-40174-0-89398400-1404769609_thumb.j
Edited by Ringworm02
72 2002tii 92-present
73 2002tii 90-92
78 530i 88-91
Depends what year car you have.
51 12 1 801 250 is the rear centre bumper for an early US car
51 12 1 816 006 is the rear centre bumper for a later US car (up to '73)
I think the change was early '71 when the rear bumper changed to the "long" sides with attached rubber bump strip.
Edited by 02Les
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
Les is correct . for the post 71 cars the profile was the same. so not sure why that bumper has a different profile  Did you happen to purchase that from ECS Tuning?
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
From the pictures you show, it appears that your supplier is sending you bumper blades from either 2500/2800 or pre 1974 Bavaria sedans, or from a 2000CS or 2800CS coupe.  Cross sections are similar, but the sixes bumpers are larger and longer.
The correct part you seek is readily available, and Blunt Tech (Steve Petersen) is a good source, both for price and getting the right part.
Cheers
FYI, Dave Varco at Aardvark has rechromed centre sections for sale>>> (619) 944 2002
73' Tii (new project) #6
68' GT4 "Track car"
69' 2002 RIP (my 1st.)
74' 2002 (Voted Best Modified BMW
So.Cal. Vintage 2011)
76' 2002
07' Escalade ESV (the money maker)
05' Ford Escort (the Beater)
I just looked at your post/pics again.
The bumper on the left is obviously for the '71-'73 set up as it has the holes for the rubber strip mounting pegs, but the profile is NOT correct. The bumper on the right has the correct profile...ie the flat portion that the rubber strip mounts to.
FYI - if you order the #656, you should get the correct '71-'73 bumper profile, but it should have the holes for the Euro in-bumper plate lights.
Give BLUNT a call/message as he will get you the correct part at a competitive price.
Edited by 02Les
Les
FAQ Member #17
