Weber Dcoe Problem
Hans
Twin 45 DCOEs, ignition on, electric fuel pump working, fuel drips from #2 barrel venturi locking bolt on bottom of carb. So fuel is getting into the barrel. I haven tested fuel pressure yet, but float levels were adjusted recently. Needle valve?
...unless the float is sinking a bit.  Then it'll do exactly what you describe.
Metal ones get holes in them
Plastic ones are reputed to get 'absorptive'.
I always carried a spare for racing, as the brass ones would crack sometimes.
But high fuel pressure, mis- set float level,  or leaky needle seat is more likely.
