1973 2002Tii Sunroof- Non Us Spec.
Teedub
1973 2002 TII ‘Euro’
Original, numbers matching 73 TII sunroof.
This has been extensively gone through mechanically by a respected 02 mechanic here in Seattle.
All fluids have been changed, cooling- including a re-cored radiator, all hoses and clamps replaced, drivetrain- including engine, trans and diff. Fuel system- including all soft fuel lines and filters replaced. Brake system completely gone through including new front pads and rotors, hub seals, rear shoes, wheel cylinders and fluid. Steering box was refreshed with rag joints and seals replaced. Ignition system- including new Bosch blue coil, cap, rotor, plugs and plug wire set. Electrical has been gone through and is all in working order lights, signals gauges, dome light etc.
Three things were changed over when imported to the US, turn signals, headlights, and speedo. These have all been replaced with proper used euro turns, H-4 lights and buckets and the 220 KPH speedo.
The interior is original so needless to say is worn, seats are the Lux fabric inserts, back seat has sun damage and is a bit rough, carpet is original but in very good shape. Sunroof has been gone through and works flawlessly. Paint is Fjord and was resprayed probably 15-18 years ago, small rust above driver headlight at the seam, spare wheel has minimal rust and the inside of rear deck lid has some inner rust as well as a 90's 'shark fin' antenna tht would propbably need to be replaced. Rockers, shock towers all clean.
This is a very solid running, driving example of what these cars are.
Any questions, please feel free to contact via cell- 206 four one 2 eight 2 nine zero.
Thanks! Tim
Year: 1973
Make: 2002
Model: TII
73 4 color Auto "The Beeter"
76 Chamonix "The Beest"
