'73 2002Tii - California Roundie Sunroof Car
Crash513
NOTICE: This is an exclusive listing for BMW 2002 FAQ members, before I list the car on e-bay
Pictures can be viewed at: https://www.flickr.com/photos/98100100@N08/
My Son bought this car 5 years ago as a restoration project that has since been abandon. He is now out of the country on military duty, and we're moving, so he's asked that we sell it on to a good home.
This is an original California sunroof car which was last restored in the early 1990's by the second owner. The body is very solid with only the surface rust and a minor paint bubbling in a few spots. The car was originally Polaris Silver, but was painted an off -white color which is pretty hazy and faded. However, it appears to have been professionally prepped when the car was restored, so it's held up remarkably well. The texture you may notice under the rear bumper is actually undercoating that the previous owner had applied when they re-sprayed the car. This has protected the undercarriage nicely, and the critical points (rockers, fenders, and shock towers) are all solid and rust free. Note the interior panels were replaced behind rear seat, package shelf, and front kick panels by a restoration shop that is known for their work with older cars. This was done to cover holes left behind by the massive sound system installation that the previous owner had put in the car.
The car starts easy and runs strong. The engine has good compression and makes great power, but does have a minor oil pan leak. In its current condition, the car could be used as a reliable daily driver as it sits. However, it’s in a condition that makes it worthy of investing in. It would not take much to get the minor problems corrected, and it would be a great candidate for a full original resto, or resto-mod.
Overview of the car:
  • Numbers matching original S10 Engine w/rebuilt Kugelfischer FI pump
  • Metric Mechanic Head (non-matching numbers) w/mildly aggressive cam
  • Numbers matching original 4 sp. trans
  • Ireland Engineering aluminum radiator and oil cooler
  • Eibach struts/shocks
  • Trunk mount battery
  • All original interior (blue vinyl/cloth seats and door cards are in very good shape)
  • Classic Cosmos 13" wheels (Not as aggressive as BBS wheels, but great ride and handling combination with the suspension mods)
  • Original California car, thru entire registration history
  • Factory hand crank sunroof
  • Original A/C car (Behr dealer installed). Removed from car, but all parts included
New or replaced since we've owned the car:
  • Guibo & center bearing
  • Alternator bushings
  • Rear transmission seal
  • All radiator hoses
  • Turn signal & washer/wiper control switch
  • Washer hoses, reservoir and motor
  • Hella H4 Halogen headlights
  • Hot Spark electronic ignition
  • Bosch red coil & disti cap
  • High performance silicone plug wires
  • Bosch spark plugs
  • 4 new Sumitomo HTR200 tires (205x60x13)
  • New battery
Things that I know need work:
  • Surface rust in several spots around beltline of car (most are sanded and primered, pictures available upon request)
  • Small dent in front of hood and trim
  • Minor leak from valve cover at rear of engine
  • Minor leaks from pan gasket (replacement included)
  • Heater valve leaks (disconnected)
  • Blower fan inop
  • Sunroof seal missing
  • Steering box loose (has some adjustment left, but will need to be replaced)
Extras on hand that come with the car:
  • Original air cleaner and filter (does not fit with aftermarket oil cooler installed)
  • Original Tii clock (rebuilt and working, $150 value)
  • Extra rear bumpers (clean, no rust)
  • Set of two Recaro seats from 318is (unrestored, but with all rails, paid $200)
  • Fully restored Autopflug front seatbelt set with retractors (paid $100)
  • Replacement oil pan gasket
  • Full set of DOT approved steel braided brake lines
  • Ireland Racing fiberglass front airdam and deck spoiler (2002 turbo style, new in box, paid $400)
Asking $9500 cash for the whole package. Car can be driven off, or I will assist with shipping. Car has clean title and current CA registration until end of October. Message me here, or e-mail to leslie.martin@sbcglobal.net
Thanks,
Crash513
Year: 1973
Make: BMW
Model: 2002tii
Body and Interior: See description
Engine and Drivetrain: See description
Suspension, Brakes: See description
'73 2002 tii Graniterot/Saddle
'17 X5 Xdrive 3.5d Mineral White/Amaro Brown
'18 328d Xdrive Sportwagon Glacier Silver/Black
