E30 rear end, axles, brakes, etc into a 2002
jakeb
Took a little bit to get the bender up and going.  Bent some pipe yesterday and will have many more updates tomorrow when I get more material.
Either way...on to some pictures.
The big tube is 1.75" .25" wall DOM
1985 e28 w/LS1/t56 and a bit more...
1970 2002 w/ m42 swap
-Contact me for m42 mounts or e28 ls1 mounts-
www.classicdaily.net
Some updates.
The box is cut with a hole saw to keep it tight to the pipe (DOM).  I am also thinking of boxing this at the bottom to be flat with the DOM.  These will be camber and toe adjustable.
Observation--are the "boxes" that contain the pivot points (for the trailing arms) low enough to clear the underbody? They look really tall compared to the boxes for the body mounts. Neat and simple idea for using a tubular structure.
Edited by nbcbird
The boxes look high but the one closest to the mount is at most 1/4" higher than the stock pickup location.  The inboard is taller to allow for camber adjustment but really no higher than an adjuster added to a stock subframe.  The tube is shifted lower (by 1/2") than the stock subframe.
thanks guys!!
  • 4 months later...
Really need to keep things updated....  Anyway subframe had to be redesigned to allow room for a driveshaft.
It is in the car for good now and the car should be running soon.
In the car
A few pics of it outside the car
In a jig...
  • 7 months later...
What was the final verdict on this ? how has it worked out in real life application , Very interested to know?Will you be selling them?
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2007 Lotus 7 Replica
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
Yes it was finished and it installed in a car.
This is how it ended up.
Yes it was jigged up and can reproduce.  The next one will end up being a little different.
If you are interested in pricing or have any other questions feel free to email me.  jake@classicdaily.net
thanks!
