Widebody 75' wheel tire size question
Windsma
Im building a 75 widebody 02 Turbo M42
and Im looking for opinions on Wheel tire fitment. The car will be raced (VIR/RoadATL) fun street use, it will have Coilover suspension with Rack and Pinion
Currently the 02 has e30 basket weaves. I mocked up the widebody kit and it measured 1in clearance to the outside.
reading A LOT.. 02's like a 4.5 backspaced wheel.
Found some 15x8  ET 0
quick measurements this would give me 4in back spacing
Also priced some RS3's  225/45-15
Should I go wider wheel/tire or play it safe?
Pics of kit purchased:
Not My car
Edited by Windsma
I don't have experience with box flares. But on my pig cheek car I'm running 13x8 et negative 10 with 205/60 rubber (iirc.) That's with bilstein sports and eibach springs. I have no clearance issues.
About to switch to IE front coilovers up front and #350 IE race spring in the back. Also switching to a 15X8.5 et10 wheel. Haven't figured out tires yet.
I
- Project 67' 1600-2
- Pig Cheek 71' 1602
What class are you going to race in?
Because that may influence your wheel/tire choice.
Yes, you could go bigger- but to start, run what you got, since it's not a bad starting point,
and see how it works from there.
Or rather, get out there, get the bugs worked out, then you can adjust tires as you go.
last seen on 22x9.5-15 cantilevers....
Then I'd start with tires you know and like, and get some about- zero offset rims to start with.
Because as you go, you'll find all sorts of variables that affect your tire choice, and these days,
rims don't cost as much as a set of good tires!
Sounds like fun!
