FOUND Early Turn signal switch for 69 2002
jgerock
Thanks to Daron Ball for sourcing a good switch.  Package arrived today and the switch will be installed tomorrow.
The original turn signal indicating switch on my  steering column is coming apart.  I have nylon zip ties holding the rear switch to the stalk.
The early Roundie TS switch is different than the later Roundie switch.  The wires terminate directly at the back of the switch and not in a harness with plug under the column.
NLA on Walloth-Nesch, Penskeparts, etc.
BMW # 613 186 48072
MFGR # 1183202001
349DD4B7-D52B-40E9-BAE3-0703B7D07B01_zps
Edited by jgerock
Correct-  forgot that last "2" after the dot.
:ph34r:
will let you know when I get to the post
Edited by dar_on_
