WTB Choke Cable and Switch
koopman
The cable should be the same. It went thru the rear carb choke pull and then another section of the inner cable was attached to it, to run thru the front carb choke pull. The connector was a black plastic rectangle with two set screws.
The door buffers that I have are different. Not sure if they will retro fit. PN 51 21 1 823 487.
