Putting '74 Tii back on the road
Jjmoonen
If I'm reading that correctly, it's the 248th '74 tii - USA version.  They didn't make many of those.  Only about 3,000 total of the '74s.  That one was probably built in Sept or Oct of '73.
Scott
02ing since '87
'72 tii Euro  //  '21 330i x //  '14 BMW X5  //  '12 VW Jetta GLI
Thanks.  Mine is a little newer...thought yours might have been built around the same time as mine.
Yours = 2780248
Mine  = 2782393
1974 2002tii Restored (Original Owner) #2782393
2013 Porsche C4S Cab (Original Owner)
BMW CCA #23777
Nice car which probably has a good soul.
Here is a TO DO LIST I am following as I refurbish my 1974 Inka tii.  Feel free to use it to check out items which might/might not need addressing on your car.
Regards and good luck,
2002#2
Repair Door Panels
  Replace Engine Fuel and Vacuum Hoses
      Install New Carpet
  Replace Fuel Return Line
   Remove Vapor Cannister
✔ Replace Vapor Line
      Touch Up with Paint
  Clean Trunk
      Paint Trunk
   Remove Old Bumpers
Refurbish New Bumpers
      Install New Bumpers
  Repair Reverse Light Switch
      Replace Rad, WP, Therm, & Hoses
      Remove A/C Remnants
      Align Headlights
      Balance Tires
   Paint Instrument Panel
      Repair/Replace Front Seats
      Repair/Replace Rear Seats
      Replace HP Fuel Line
   Replace Front Kidney Grille
  Repair Floor Pans
  Refurbish Bumpers
  Install Bumper Guard Shims
  Install Refurbished Air Filter Housing
Tune KF Fuel Injection
Replace Rear Brakes
Replace Center Drive Bearing
✔    Replace Tie Rod and Ends
   Overhaul/Repair Heater Box
  Overhaul Heater Valve
  New Rims and Tires
   Install Correct Fuses
Remap Fuses/Diagram
  Recover Trunk Floorboards
  Paint Air Filter Housing, Ignition Coil, and Jack
  Repair Door Brake
  Remove Old Carpet and Padding
  Refurbish Seat Belts
  Replace Headlights
  Torque Wheels
      Install New Steering Wheel
  Install Sound Deadening
      Overhaul Door Interiors
      Repair/Replace Driver’s Rear View Mirror
      Replace Battery Cables
      Install New Washer Motor
  Clean Vapor Canister
  Prepare Spare Tire Well
      Replace Cowl Drains
      Replace Brake Lines
  Replace Firewall Screws
  Paint Extra Cluster
Paint Brake Calipers and Drums
Remove A/C
Remove A/C Detritus
  • 9 months later...
Its finally time. I will be going to retrieve this gem from its long term storage. I can't complain though. It was heated storage and it was cheap.
Now I can finally start to dig in and see what all is going to need to be replaced. Im looking forward to the job that lies ahead.
