How have you cleaned up your engine bay? Pics and explain please.
Vicleonardo1
some great lists of things to do so far and some nice clean ups.  the simple version is take everything out, clean everything up...
and only put back in what is absolutely needed..... :)
I like it:
Step one: Remove engine.
Step two: Replace engine clean.  :)
It looks like you relocated the washer fluid container.
Relocated the battery.
Is that an oil collector/breather on the far side?
1975 Malaga. It is rusty and  springs an occasional leak.  Just like me.
I like it:
I do prefer the simple solutions.... :D
windshield washer system completely removed.
battery under rear seat.
yes.
2xM3
Some very pretty engine bays.   If I remove my engine I'll be standing in there doing the same job.
Note:  If you do remove (most) of the engine, as like LateApex, you can get inside the nose clip much easier via the radiator opening to paint it as well.    BMW did a half-ass job originally.    You'll notice only a light coat of paint on the inner surfaces as well as the underside of the top shelf of the clip.    Now's the time!    I did mine the hard way - upside down, twisted, double-jointed strokes, mostly through the front grill openings.
73 Inka Tii #2762958
So Pete, I hope someday you make it into the hall.
Is that a new brake booster and cylinder? It looks pretty sharp.
