Rear seat belts - Autoflug - $20
Front seat belt inner latches - $10
Hood Latch assembly - rod, springs, cable - $50
Jack - $50
Headlight buckets pair - left & right - all fittings free, surface rust - $60 pair
Headlight bucket - driver's side, rusty but operable - $20
Battery tray - include hold down - $30
front vent window gear controls - 3 sets of left & right - $10ea
trunk latch (panel mounted) - operates freely - $20
door latch pair - left & right - good condition - $20 ea
trunk floor panels - wood - one pair - one tank side - some stains, good vinyl - $40 ea
Relays - all 3 from under hood, - $20 ea
Fan switch - plug type - $40
Porcelain resister, $10
Coil holder - $5
door handle - left, fair chrome - no keys - $20
window crank handles - 3 - ok some pitting, inserts have some marks - make offer
Vent window knobs - 4 -  fair, no inserts - $1 ea
Door handle inserts for inside handles -
Grab handles - roof mount type - very nice - $30 set
Flag mirror - brushes aluminum - good glass and nice outside - $40
Horn contact ring - 2 (between steering wheel and column cover) - $15 ea
trunk lock cylinder - works but no key - $10
Gas cap- one non locking, one locking but no key - $20 ea
Door threshold strips - gray plastic - for screw style - excellent - $40 pair
intake manifold - $40
Alternator - $40
Exhaust manifold cover - thick aluminum (earlier type) - $40
fuel tank pick up - believe to be fuel injected type - $40
fuel tank, base model - needs cleaning - $75.
throttle linkage - long vertical rod and horizontal rod with firewall mounting - $40
Starter - unknown condition - turns - $20
glove box - good pad on front and latches - $20
Rear panel aluminum trim  - 3 -  the squarish one - each needs sand/buff/ polish (I can do) - $30
Chrome belt trim - many pieces in various conditions but all would need to have anodizing removed and then be sanded, buffed and polished.  Tell me what you need - make offer
Steering wheels, 3 spokes, One with horn buttons on spokes, One with horn in center - fair
make offer
Steering column with key - seems good - not sure what year - 6 pin - no buzzer electrics - $40
Vent glass with frame - front - $30
Battery ground strap - copper - a little fraying - $20
Exhaust gasket ring between pipe and center section - new - $?
Steering shaft rubber vibration isolator - $10
Intake manifold gasket set - $10
Old style steering column lock - no key make offer
Edited by Makinwaves
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
