Tie Rod Center Link
Danz3
I am in the process of rebuilding my steering box.  The rebuild is done and all seems well with the box.  Last night I was planning on reinstalling the box and buttoning up the steering.  When reconnecting the center tie rod link to the drop arm I noticed that I somehow screwed up the threads on the ball joint and can't start the castle nut on the threads.  What are my options?  Replace the center link ($), try to chase the threads with a tap (if I can find one, M10x1)?  The ball joint doesn't appear to be replaceable in the link.
The proper re-threading die is indeed hard to find.  I think I got one from McMaster-Carr.  It is fine thread, M10x1.0 sounds right, but I'm not sure.  It's at home.  I might be talked into dropping it in the mail sometime, but I am a bit busy.
Bring a Welder
I'd get a new one if I didn't know the history on the old one. If I knew the history and it was good, triangle file till it bolts up.
-Nathan
I was just checking my random die collection, because I know I've done this and bought the right die. My dads big tap and die kit did not have the right one, so I bought one. The only one in my random collection that looks reasonable says 1.25 on it, not completely sure about the width as its not marked. So be certain you've got the right one.
Edited by KFunk
Bring a Welder
Since you can't easily use a die on a rotating balljoint, I've gotten out of similar emergency situations, using one of these style thread repair tools. I think I paid about $25 for the one I have. It's small (about 2" x 2")
I've never had much luck with thread files, personally. Be sure to use only new lock nuts - always.
Sears sells 'em!
http://www.sears.com/craftsman-cm-universal-external-thread-repair-tool/p-00938948000P
Edited by wegweiser
Paul Wegweiser
Be very careful using thread cutters (taps and dies) to clean threads. Thread chasers are more gentle, and less likely to start a new set of threads. that said, this is one fitting that I wouldn't want to fail because of poor threads.
Except that, if the nut tightens this joint, all it does is wedge the taper into position, and then act as a safety.  It should have wedging tension
on it, no more.
THAT said, I have found that the center link is the one joint on a 2002 that fails in regular use.  Tie rods last forever, ball joints close,
center links seem to be good for 50k or less, if you spend a lot of time jumping curbs.
Has anyone used the OEM BMW link?  It seems the 'good' OE's (Lemforder, etc) don't make the center link anymore, and BMW only gets $130 for it.
