Air filter housing to body bolt
rapandi
Go to solution Solved by Son of Marty,
Most metric bolts with 10mm heads & 10mm nuts are 6x1 thread size (6mm diameter, 1mm pitch).  That's the metric equivalent of a 1/4" x 20 SAE bolt--very common.  Easily found at your local hardware store.
rapandi,
if I get to Brisbane this May, I fully expect to see those M6x1's installed ........
Cheers,
Carl
Hahaha..... Carl I am in Brisbane, Australia and not in Brisbane, California!!! It would be a long way to come just to see the M6 bolts. To make it worth you while I will get them yellow plated!!! Just for you....
Raj
1972 BMW 2002 Tii - Golf Yellow
Going to spend all your time with the banana benders in Queensland or are we all going to get a share?
http://www.australiangeographic.com.au/topics/history-culture/2013/05/slang-what-aussies-call-other-aussies
Edited by Simeon
rtheriaque wrote:
