Weber DCOE 45 Tuning on a lightly Modified Engine
CaptJ
He has a 2bbl Lynx setup, not individual runners, Lee.
And again, in more general terms, the 'breathing area' on a plenum system (either a 1-2 like the Lynx or a 1-4 like the stock downdraft)
has a 'time component'- on a 4 cylinder car with 2 cylinders on one choke, those cylinders both see that 45 mm throttle plate.
Since they alternate, the average FLOW through the barrel doubles, but PEAK VELOCITY through the barrel is no different than if it was individual runners
OR if all 4 were breathing through that one throttle plate.  And PEAK VELOCITY is what the 'chokes' (venturis) regulate most.
Corey, get a new seal kit into your carb, clean i out well,  bolt it back on the car the way it is,
get a wideband meter working, and see what happens.  Your idle problems
are NOT choke related AT ALL, and you can mess with the idle air screws and idle mixture screws
and CERTAINLY get it to idle and transition better.
There IS no black magic in these things.  It looks like there is, but once you figure out how all the (complicated little) parts
work and interact, suddenly you find that they are very reasonable indeed.  And the wideband is crucial to that-
your ass can't tell that a 35 idle is a little lean and a 45 idle is a little rich, but the WB can, and will, and suddenly that
number will turn a light on in you noggin.  And btw, the 'idle' jet is really a 'transition' jet, as it regulates the fuel to the carb
AFTER you get off the idle circuit and before the main circuit starts to really flow.  So if your 'idle' jet is all that is determining your
idle mixture, then the throttle plates are open just a bit too far.  Open the idle air screw a bit, and try again!
The chokes will only come in at higher throttle angles, and if they're too big (I've never played with the Lynx, so I don't know)
then where you'll have trouble is at low- throttle- angle cruising- like, 45 on a side street, or even 75 on the highway.  It doesn't
take too much to keep a 2002 going, so the idle and especially the progression circuits are where the car cruises on the freeway.
And it's the transition onto the main jets that the venturis (chokes) will affect.
Pat Braden, Weber Carburetors
Haynes, Weber Carburetors, Including Zenith and SU Carburetors
Dense, and you learn by reading, trying, getting confused, re- reading, re- trying, looking at the WB numbers... eventually, the light comes on.
It's cool.
hth
Edited by TobyB
Thank you for the feedback Lee and Toby.
For now I'll rebuild it as is but I will definitely keep your thoughts in mind Lee.
Now for gasket kits. I seem to have found three completely different kits. Not sure which one to get besides getting the 2.00 needle and seat.
https://www.webercarbsdirect.com/ProductDetails.asp?ProductCode=92.1047.05M&CartID=1
http://www.piercemanifolds.com/ProductDetails.asp?ProductCode=92.3247.05&CartID=2
http://www.carburetion.com/_aspstuff/cucart.aspx
Thank you!
  • 9 months later...
Reviving an older thread. I recently purchased the Top End Lynx kit and installed it on my car. Didn't like the throttle cable it came with so fashioned my own linkage out of left over Weber/Korman parts I had...works very well now. My issue is that I have run through the steps of tuning and adjustment and just cannot get the carb to behave. It will idle well (once warm) and will run fine at slow speed, but once I stomp on the pedal, it bogs down completely and studders. I know it has to be an air/fuel or jetting issue so thought I would ask here. I do have an aspx digital wideband sensor I just installed as well.
My car:
E12 head with:
  All casting removed from rockers
  Schrick 292
  Port and polish
Engine:
  9.5:1 pistons
  Bosch black coil
  Pertronix electronic ignition
Intake:
  Lynx manifold with (1) Weber 45 DCOE
Exhaust:
  Stahl headers
  Stebro straight pipe with resonator
  Supersprint exhaust
Linkage is smooth and opens to full throttle
New NGK plugs
New Filter King resonator/filter set at 3psi
New fuel line (electric fuel pump in trunk)
Intake came with new gaskets as well as soft mount gaskets for carb
Weber carb came in the box with the following: (Note difference in sizes that are recommended in Dick's post just above)
Choke 36
Main 145 F16
Air 155
Idle 55 F8
Pump 45
Before I start throwing new jets at it and/or tuning any more I figured I would ask your expertise. Oh...as far as air filters go...I have run it with the air horns provided in the kit and with/without the screens. I also have a set of curved Corsa Velocita stacks with the red filter. If I don't use those I plan to run Uni pod filters or a Itg Megaflow filter.
Thanks!!!!
Greg
'76 02 (Pastellblau - my 1st car - owned since 1992)
'04 330i zhp (Monaco Blue)
'07 328i 6spd (Titanium Silver)
'11 X3 (Alpine White)
Quote
So, then, when it misbehaves, what does the wideband say?
If you're going lean, it's very likely a fuel delivery issue.
If it goes lean immediately, the carb's not delivering enough.
If it goes lean 30 seconds later, the fuel pump's the issue.
hth
@Hans - Timing was fine with previous setup, but can check. Yes, regulator is set to 3psi per another thread I on here I read...let me know if it should be different.
@TobyB - Ha!...no I don't think I even tried to read it when it bogged down. I will do that!
  • 3 weeks later...
Okay, finally got the time (and the garage wasn't freezing) to play around with the car today. I installed a set of Uni pod filters on the velocity stacks that came with the Weber 45. They fit well and I know will have proper filtration. Got the car started and warmed up and got the following:
At idle the wideband fluctuates around 12-13.5. It doesn't seem to sit steady, but that could be the fact I got the readout instead of the gauge and it fluctuates more.
When I go to FOT the car bogs down immediately and the read-out jumps to 19 (this is lean correct?). The car will die if I hold it.
So...what to do next? If lean, then up the fuel pressure?...it is at 3psi now.
Hi,
Pressure alone is the wrong approach in any case, you will only force the needle valve to leak and overflow the bowl. The only "pressure" you might want to check is the level of fuel in the bowl. I see that you have considered it, but how did you measure it? Best method is the "in place" method of measuring via removing the jets/emulsion tubes and checking the actual level of fuel in place after the pump has filled the fuel bowls and closed the valve. You will have to google that though, I don't have a good description but I have used it a long time ago. The method with removing the cover/float assembly and measuring the distance of the float to the valve and float to maximum opening position is the method described in the Weber handbooks and most often used. If the tabs or float arms are bent though, then the measurements can also produce the wrong result with both methods I would guess.
As Simeon said, if the pump jets are the incorrect size or the pump is not working at all or not delivering what it should it will run lean. If opening the throttle quickly induces it and it stays normal when slowly opened, that would point to the operation of the pump jet. The pump jet only delivers a certain enrichment for a brief period to avoid leaning out under acceleration, but its operation is limited so if the engine never recovers then that might also not be the cause. But as noted, if the float level is incorrect, that would lean the mains and reduce the operation of the pump jet, they share the same fuel from the bowl. I would first check the float level, then check the pump jets for correct operation and check what size they are. There are methods for measuring the operation of the pump jet , but I have only check whether they work at all. I remember seeing something somewhere about spray pattern and distance, but someone else can probably provide much better input there.
Andrew
Edited by Oldtimerfahrer
1971 2002ti, 1985 E30 320i, 1960 Land Rover 109 Ser 2, 1963 Land Rover 88 Ser 2a, 1980 Land Rover Ser 3 Lightweight
What happens if you roll into it?
With a DCOE, it responds differently to a gentle throttle than a stab.
The pump jets help get you up to speed,
but then the mains keep you running.  Float level first,
and then make sure you have enough fuel to keep the float bowl filled.
If the car dies at WOT, this almost always means not enough fuel in the bowl,
or way too much getting through somehow- flooding will do it, but
that's pretty unusual...  and your wideband says you're starving.
A temporary fuel pressure gauge will tell the tale- if you have even 1 psi,
you have enough.
Here's what I do to diagnose a lack- of- fuel problem- run it WOT until it dies, switch off immediately,
then check the fuel level.  On the DCOE, it's super easy with a dipstick down the jet cover.
If the bowl's dry, then start looking at your fuel supply.  Starting with the little screen in the inlet...
hth
