1974 2002 Tii
lrsm2
Year:: 1974
Make:: BMW
Model:: 2002 Tii
Price:: 21500
I can deliver this car anywhere in the Continental US
Calif car brought to Florida 10 years ago
Original Books and tools still with the car. Original Motor is still in the car
Updated with a 320i 5sp trans and 3:90 limited slip differential
original Frigiking AC updated with a rotary compressor, high efficiency condenser, hoses and aux cooling fan.
Radiator was just rebuilt with a high efficiency core. Stays at 1/4 on the gauge with AC running in Miami traffic.
Just had a windows out, base coat, clear coat respray in it's original "Atlantique Blau"
The body is very straight, any rust issues were dealt with except for driver floor pan. Shock towers front and rear clean/solid and original
Rockers/doors etc clean and dry
All new rubber, windows, doors, trunk, engine compartment, door handles, taillites
Rare original left and right factory chrome mirrors.
Rare Euro flat turn signal lenses correctly modified to work US code running light and turn signal
Updated door brakes, Battery relocated to trunk
Original bumpers "tucked" close to body for best possible appearance
100Amp alternator with internal regulator
top end performance header, exhaust system is new
Centrifugal advance distributor with Pertronix electronic ignition
The cylinder head was recently rebuilt. The bottom end of the motor is Original and will need freshening eventually
All hoses, belts, water pump, fuel injection lines, motor mounts, brakes, clutch, driveshaft components, shift linkage, shocks, suspension components are new or rebuilt
It has Suspension technique springs lowering the car 1 - 2 inches
Currently running period correct American Racing "Libre" wheels. 13 X 6 with fairly new 205x60R-13 tires.
Comes with a set of 320i alpina style mags and tires and OEM steel wheels.
interior is fair. Dash has some cracks, Seats are ok front and rear, door panels have speaker cut-outs
Headliner is original and has a split above driver sunvisorpost-38732-0-71835000-1458930364_thumb.jpost-38732-0-33240000-1458930346_thumb.j
post-38732-0-87560200-1458929462_thumb.j
post-38732-0-63034100-1458929475_thumb.j
post-38732-0-60064600-1458929488_thumb.j
post-38732-0-72139300-1458929501_thumb.j
post-38732-0-86238300-1458929516_thumb.j
post-38732-0-78926700-1458929537_thumb.j
post-38732-0-69234800-1458929555_thumb.j
post-38732-0-30004800-1458929569_thumb.j
post-38732-0-08283400-1458929586_thumb.j
post-38732-0-24241600-1458930334_thumb.j
Edited by lrsm2
update
