Radius rod bushing replacement
LateApex
It probably could be done, but I've always thought removing a few more parts makes the job quicker and easier, and I've been proving it to myself more and more recently.
I just re-did all the front wear parts, so I had to pull everything apart, but just for that job, you could:
remove the caliper, hanging it wire from something other than suspension, (no need to rebleed)
Then remove the bolt at the subframe, radius arm, undo sway bar and strut bearing and the whole thing should come right out
Now you can do the job on the bench, rather than upside done in the car....
just my $0.02
You mean the ones in the subframe, right?
Yes, they can, but the nose bodywork may get in your way.  if you don't
mind bending the front lip up so that you can get to it, then no problems.
A rusty or bondo'ed nose may self- destruct when you try the bend.
But it's just one layer, and if it's not pristine, but not really ratty, then it'll bend out of the way.
Or you can lower the subframe the 3/4" or whatever it takes.  That's not
too hard, either- if you're
If you have the rubber bushings still in there, then you need to figure out
a puller that won't mack you schnoz any more than it has to;
then it's pull the big pivot bolt out of the subframe where the suspension arm's attached so that the strut will lean back
enough to get the radius rod out of the bushing, and have at it.
I've never had to mess with the brakes or anything- if the bolt's out, the lower
suspension arm can pivot freely on the ball joint so that the radius rod can come out.  It's a bit
fussy, but it's not too tricky.
Unless you drop the car on yourself.
Edited by TobyB
