Stainless Steel Beltline Trim Kit Installation. Share your tips/experiences
Delia
I am curious to know the kinds of experiences you folks have had with the ten-piece stainless steel beltline trim kits.
Specifically, how easily does it install and what tips/tricks are required to close the gaps on the curved corner sections.
TIA
1973 2002tii - gone
Inka (aka "Orange Julius")
#2762756
1974 2002tii - gone
Polaris (aka "Mae West")
#2782824
1991 318is (aka) "O'Hara")
Brillantrot - High Visibility Daily Driver
BMW CCA #1974 (one of the 308)
deliawolfe@gmail.com
HI,
  the installation is really easy. but i recommend
pre-fitting the parts before a paint job. also buy
new metal "T" clips for the ends where you attach
them to the door, hood, trunk and quarter panel. also
get some washers in graduated sizes to make the
nut have something solid to press against. for the
hood and trunk, make sure to lower the lid slowly the
first time to test where the ends of the clips reach.
sometimes they can scratch the body if they are too
long.the closure cilps are easy if you leave the "T"
clip loose and then slide the closure clip over the
gap with a plastic putty knife or windshield tool for
glass work.in the past i have been able to buy the black
plastic body clips with a rubber flat gasket on them
and this seemed to keep them tight. blue masking tape
can also make the job safer for the paint until final
tightening. lets see what others add in.
stone
stone racing co
phila pa 19123
Not *easy.*
*Easy* is the stock trim.
I can do the stock trim in a couple of hours - including removal of the rear interior panels for that fussy t-bolt on the rear quarter panel.
This stainless steel system comes with its own hardware and covers for the joints on the trunk and hood.
I'm far more interested in getting the "J-shaped" stainless pieces to conform to the contours on the trunk and hood. Tightening the nuts as much as I dare still leaves an unacceptable  1/4" gap.
The properties of stainless steel are quite different from the original aluminum.  Those "J-shaped" pieces are quite stiff and cannot be twisted to close the gap.
Also, the profile of the stainless steel does not consistently match.  Straight pieces have a different profile than the curved pieces.
1973 2002tii - gone
#2762756
1974 2002tii - gone
#2782824
There are some posts on this somewhere. I had a set of this trim and sold it onward with disclosure that "easing"/fiddling/cussing would be likely. I bet a call to La Jolla might help if not tried. Would love to see photos of a successful install.
Mars Attacks!
The stainless steel trim kits have fitment issues on the curved pieces that leave noticeable gaps in the corners.  No amount of fiddling could fix the problem.  I ended up going with Wallothnesch trim for all the straight and curved trunk pieces and refinished my 2 curved hood pieces to save some cash.  The Wallothnesch curved trunk pieces fit great, no gaps.
Good luck,
Mark92131
1970 BMW 1600 (Nevada)
  • 1 year later...
Resurrecting this thread for any current commentary.
I just purchased a set second hand but unused and found the OP's comments to be correct.  The radii are all wrong for the hood and trunk.  I've shown the new SS piece overlaid the original and the differing radii are obvious.
HELP!
Edited by BenjaminSmith
add photo
I thought I was man enough to install this SS trim I was not...the corners will NOT work or make the compound corner where it has to turn and be on a pitch to form to hood.
..I have a set I’ll make someone a deal on, it has one piece damaged where I Tried heat to help bend / pitch...
make nothing happen…
I, too, am a victim of the LaJolla kit. Unbelievably poor fit...impossible to bend around the corners of hood and trunklid. Piss=poor finish of some of the bits, too. It nearly feels like the kit was made by clever sweat-shop kids that had been shown a blurry photo of a 2002 once or twice.
