Ground strap under the hood - 2002
John_in_VA
12 hours ago, Buckeye said:
JimK, is it possible to post close up picture of tat ground strap. is it braided, strand or solid wire?
By definition a strap is a strap not a multi-strand wire or solid wire.  Ground straps are usually braided straps where there is flexing.  I would not pay a BMW price for a strap but go anywhere for a short strap.  This one seem almost too long for the installation and super sized for the static charges that may be developed by rubs or even shielding.
Gotta admit...in 47 years of messing with 2002s I've never seen one with a hood ground strap--but I do know a whole bunch of ground straps came with both Becker and Blaupunkt radio install kits (I used to install them in new Peugeots at a dealership).  My AM radio is nice and quiet without even a condenser on the alternator.
But at least now I know what that stray bolt hole is for...never knew before.
For those interested here is some details from Motorola from the 70's that noted the interference from unbonded body panels. It also reminded me of another one from static build up from tyres (I have heard of this being treated with carbon granules poured through the valve stem.
http://www.quest4.org/radio/reducing_noise_interference.htm
Most of this stuff is not relevant for modern FM (or even AM) radio properly installed
rtheriaque wrote:
7 hours ago, JohnH said:
.... and they are only $5.44 from your local dealer.
Realoem.com shows $5.44, but prices there are often outdated.  BMW MSRP appears to be $5.24, with online discounts getting you down to $4.19.
Thanks for the help in finding the part number.  The radio sections of realoem.com for E28 & E30 show a number of other ground straps from 280 to 400 mm in length, in addition to others with no dimensions stated.
65311356255 applications:
http://www.realoem.com/bmw/enUS/partxref?q=65311356255
E28 ground straps:
http://www.realoem.com/bmw/enUS/showparts?id=DC74-USA-07-1985-E28-BMW-535i&diagId=65_0054
E30 ground straps:
http://www.realoem.com/bmw/enUS/showparts?id=1413-USA-07-1987-E30-BMW-325i&diagId=65_0120
John in VA
  • 2 years later...
I just tried this grounding strap and was pleasantly surprised. Picking up more HD stations and overall stronger reception across the FM band. My reception problem didn't seem like spark plug noise, just overall weak reception. I was planning on re-doing the antenna but this seemed to do the trick. Now radio even works pretty well with the antenna retracted for some stations. Didn't want to mess with cleaning off the paint around the factory hole.
Edited by 7502
spelling
  • Like 4
On 9/2/2016 at 4:19 PM, Stevenola said:
The straps were included as part of the radio installation kit back in the day.  So probably not a BMW part number.  My car has a Becker and the kit included a hood ground strap, a valve cover to firewall strap, an ignition coil doohickey, and alternator doohickey and a voltage regulator doohickey.  So as mentioned above a thin generic braided strap would do it.
I was about to post the same thing. My Becker came with a box full of straps and gizmos for suppression. Still have the instruction sheet somewhere -  and some spare gizmos.
Photos, please!
Thanks and regards,
