1974 TII Electric Fuel Pump Options
buckweber
Original fuel pump is shot.  Can't afford a new TII pump.   Read that a 5 series and/or 3 Series fuel pump will work.  Need to visit junk yard to find a replacement.   Is there specific models, years that I need to look for.
Also....  The original reserve canister is no longer with the car.  Is that needed or can I go with just a pump?
Any help would be most appreciated.
Don't buy a used fuel pump. Buy a new E28 pump. Plenty of info on the install here on the FAQ, probably an article all about it as it's commonly done.
Andrew Wilson
1 hour ago, OriginalOwner said:
"direct current thingy"
Sorry, poor wording.  I've attached the picture.  I don't know why this dc voltage thing is involved.  Unless it's 74-76 modification.
Thanks to Kreeger for their picture and fantastic site.
Wait... is it just the connector?  Edit: Karl, you just said that.  :o     It looks like an electrical component of some sort.  It's what I inserted my spade connectors into.  IMHO, it's much easier to re&re without crimping the original lines.
I covered the whole connection with shrink-tubing.
Edited by PaulTWinterton
73 Inka Tii #2762958
1 hour ago, pilotnbr1 said:
does the e28 pump have a built in check valve
All the modern pumps have check valves.  They usually don't hold pressure though, i.e. pressure leaks down pretty fast.  The main purpose of the check valve is so the pump (a positive displacement device) can work.  Without the check valve, the fluid pumped would flow back between pump discharges and the pressure would pulsate like crazy with little or no flow.
Thanks!
74 tii
"I know just enough to be dangerous"
  • 7 years later...
On 10/17/2016 at 11:28 AM, chargin said:
I used the e28 pump retro fitted to the Tii bracket, then added some jumper wires to mate to the Tii harness
UPDATE:
I had to go up in gauge on the wires, the original Tii harness over heated and stranded me roadside
Also added a Impact/Roll-Over switch for some additional safety
  • Like 3
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
