Torque Specification Front Axle (sub-frame)
Buckeye
In process of rehabbing front suspension and not sure what is the correct torque specification to fasten front axle beam (sub-frame) to frame rails. Haynes manual says 52+4 ft-lbs. and BMW Service book does not exactly uses similar term "front axle beam/sub-frame to frame rails", but it says "Front Axle Beam to Engine Mounting". So like to ask experts which one is correct?, and if neither one, what should be? I have included front axle torque specification here for reference and verification.
Thanks,
FA
76 2002 Sienabraun
2015 BMW F10
42 minutes ago, jgerock said:
Did you take a look at the FAQ torque listing in the archives?  I just looked at my printed copy and it only has the rear subframe to body spec (about 100 lb-ft).  I know I have this somewhere
I did and no indication of sub-frame to frame rail there
13 minutes ago, jgerock said:
Haynes 2002 manual shows front cross member bolts at 52lb/ft.
haynes 320 manual says front cross member bolts at 133-145 lb/ft
I recall Haynes calls for 52+4 ft-lb, and tried it on one bolt, but felt like I couldn't reach final torque (click), so I stopped.
So still looking in the BMW service manual, but dice. I have read people sheared off bolts at this assembly joint before and I want to avoid that.
76 2002 Sienabraun
2015 BMW F10
A lot of the bolts will shear when they are loosend due to rust, when installing them they are a tight fit and any miss alignment of the subframe or body due to accidents will cause one or more of them to cross thread with disaster following shortly.
George S Patton
here are the facts found regarding sub-frame bolts: they are M10x30 and M10x50 grade 8.8
According to Tightening Torque Value chart in the Introduction section of BMW 2002 Service Repair Manual
torque value for a M10 thread bolt grade 8.8 is 4.3+0.5 mkp or 30.96+3.6 lb/ft
My conclusion is that the values given in Haynes manual (52+4 lb/ft) is incorrect.
Thanks for all your inputs.
76 2002 Sienabraun
2015 BMW F10
