BMW E39 M5 FOR SALE
tiiii
01/2003 BMW E39 M5  "A" 354 Titanium Silver paint, "A++" black leather & brushed titanium trim, "A++ mechanicals.  26K.
BMW M5 Maintenance & Mods
01/2003, S62 5.0L ENGINE, VIN WBSDE93443CF92779, 139084 mi.
Owned and sometime daily driver by BMW/M-Benz Shop Owner
Never tracked
Never any serious fault codes
Chassis
Paint: #354 ‘Titanium’
X5 (E53) Fr. Control arm bushings
Polyurethane sway bar bushings Fr. & Rr.
Bilstein PSS9 adjustable coilover struts & shock w/mounts
Michelin Pilot Super Sport tires – excellent tread, no uneven wear
Bronze bushing brake caliper pins
Stainless Steel brake lines w/flushed Pentosin fluid
Akebono ceramic brake pads Fr. & Rr.
Tie rod ass’ys & idler arm all replaced
OE wipers
McGuard wheel locks (4) & 2 sockets
Auto-adjusting headlamps pivot points repaired
New
-       Fr. Grilles
-       All badges
-       trunk release latch
-       Interstate H9 battery
-       Hood pad
-       Fr. Fog lamps
-       100W hi-beam bulbs
Drivetrain
Clutch & Pressure plate replaced
VANOS units (both) replaced & refurbished
BMP Adjustable short shifter (#192820) w/E90 ZHP illum. leather knob
Shark Injector Fuel Injection/Ignition Timing reprogram & 7400rpm cutout
No fluid leaks, no oil consumption
Engine oil pan drain hole reinforced with Time-Sert
New (replaced within the last 1½ year)
 -   rod bearings
-       ignition coils
-       spark plugs
-       Mass Air Flow meters
-       O2 sensors (all four)
-       Air, oil, P/S, cabin filters
-       Engine oil (LubroMoly 10W-60 synthetic)
-       Transmission lube (Redline MTL), all synchros good, no gear whine
-       P/S fluid & reservoir
-       Differential lube (Redline 75/90 synthetic)
-       Freon
-       Both drive belts and all associated tensioners & pulleys
-       thermostat
-       Radiator, water pump, accessory cooling fan & shroud, coolant
-       OE wipers
-       Brake fluid (ATE DOT 4)
Interior
Nappa Point Black leather – “A+”
Door pocket ashtrays removed (non-smoker car)
Alcantara visors & roof lining (code 775)
Brushed titanium dash & door trim (was wood)
Fr. L. seat motor drive recline cables
Fr. L. seat cushion padding O.E.
Instrument cluster replaced entire (all pixels good)
Climate Control faucets & fluid pump “BISA water valve” replaced
M Audio (code 752) w/CD changer (code 672)
Folding Rr. seats w/pass-through
Power Rr. sunshade
Parking sensors
Navigation (code 609)
Rain sensor
OE M5 Floor mats
E90 OBC knobs
All Series options
-       all interior controls work 100%
-       no cracks in dash
Accessories
Dash Mat
15L LubroMoly 10W-60 synthetic engine oil
Bentley E39 workshop manual, 2 vols.
1) kit BMW wheel cleaning brushes
1) extra main key
5) 6-CD magazines
2) camshaft position sensors (not installed)
4) ignition coils (used but test ok)
2 each) engine oil, air filters
1) plenum cover gasket
1) spare, complete, 100% functional OBC display unit
1) spare, complete, 100% functional 6-CD changer unit
1) spare, tests good MAF
3) D2S Xenon bulbs
2) H7 100W bulbs
2) “angel eye” bulbs
Damage
Dime-sized ding center hood
Parking bumper rash on underside of bumper chin
Typical abrasion on stock M5 wheels (still “A” – “A-“ condition), no curb rash
No collision damage history
R. subwoofer basket cage missing
Clear coat abrasion on roof rack rail.
Pending
Airbag recall – in dealer queue
Replacement of bashed Fr. R. fender wedge undercar panel.
  • 1 month later...
Thank your for this, 442 stang. . . . yup this one is 100% good-to-go, track or cruise. Ck:
https://santafe.craigslist.org/cto/6059519070.html for more info.
I just loved it; my gift to myself for 30+ yrs in the shop on BMWs. Besdt ergonomics ever, esp. with the M/T & clutch. Double-shifting on this at full rpms is a dream come true. Had my fun, now investing in cold-weather mountianeering gear.
If 442 is Olsdmobile (?), why stang or is there a Ford 442?
