Instrument cluster lights are dim
Mike Davis
As we all know...3rd time is a charm....Are LED's dimmable?  :D
IMG_2372.thumb.JPG.e7e3af0b0aa0caca300d6bc2219a74c9.JPGIMG_2375.thumb.JPG.a9981be09eaaf92752e9ad7c0afaa1ae.JPG
I just placed a mat on the ground for my knees and reached up under the dash and found the nuts holding the assembly and the speedometer cable and pushed it out.
Edited by BeMyWay
Light is seriously underrated.
It's depends.
LEDs are current sensitive devices.  There is a minimum voltage threshold where they will power up.  There is also a maximum voltage threshold where they will burn out.  Typically, lowering the current will cause the LEDs to be less bright; increasing the current will cause the LEDs to be more bright.  With that said, whether they are dimmable or not depends on the power supply and/or the driver circuit or chip.  I have replaced all incandescent bulbs in my '02.  They were all dimmable.
Below is the chart showing the typical relationship between Ir(forward current) and brightness (relative luminous intensity).  The higher the current (resulting from the higher voltage - this relationship is dependent on the power supply or the driver chip), the brighter the LED up to a point.
Edited by Tsingtao_1903
14 minutes ago, Tsingtao_1903 said:
It's depends.
Good to know, I think. The reply still doesn't answer the question.
LEDs in our cars = dimmable= yes/no?
Don
As questioned before, are the LEDs dimmable in our cars?
Don
Don
On 3/14/2017 at 6:39 PM, Mike Davis said:
Now how many l.e.d.s are in the cluster, what light # and where to order?
If memory serves, 4 bulbs for instrumentation lighting.  1 for the brake light, 4 for the indicator lights.
In my case, I used 5 blue LEDs: 4 for the instrumentation lighting, 1 for the high beam. 1 amber for ignition on, 1 red for charging and 1 for the brake light indicator, 1 green for turn signal indicator.
Search for T10 wedge LED.  Ask the sellers and go from there.
Good luck.
Don
As with many things, the answer is "that depends".
LED's like to be pulsed (PWM), not driven DC.  To dim them, you lower the duty cycle.  In our cars, there is no provision for PWM, just a rheostat that lowers the voltage to the bulbs.
If the illumination bulbs are wired in parallel, as they most probably are, simply replacing them with LED's can create issues.  One should always put resistors in series with LED's if they are to be ganged in parallel.  The reason being that as LED's warm up, their forward voltage (Vf) drops.  Since LED's are not matched in their Vf values, the one with the lowest Vf will draw the most current.  As that happens, it warms up more than the rest and its Vf drops even further.  You see where this is going...
Using the stock rheostat is fine if you can put resistors in series with each LED.  While it's not the most efficient way to drive the LED's, in practical terms, it ought to work just fine.  Make sure you know the resistance of the rheostat, and that at the max brightness position it isn't going to apply 12 volts directly to the LEDs.  That may burn them out.
I would suggest putting all the illumination LED's in series, if that's possible with the cluster.  A single resistor to protect them and you're good to go.  LED's in series have the added advantage of seeing the same current, yielding more uniform brightness.
Therefore, it depends :-)
Absolutely correct.  I did not even know where to begin to explain this.
Automotive LEDs have an internal resistor to limit the maximum continuous current.  A typical max current rating is 35 ma. A typical internal resistor is around 300 ohms. That is the only way they can be sold as 12 VDC bubs.
The max current is  specified as typically something like 30 ma.  BUT this can be time averaged.  In an instrument we manufacture we run pulses of current MUCH higher than that using a pulsed constant current source.  We then use frequency modulation (rather than the much more common pulse width modulation) for technical reasons. We use a pulsed constant current source (a single point on the curve provided by Tsingtao_1903 above) to achieve luminous linearity with frequency over a broad range.  (We work with frequencies up to 300 KHz . . .)
The big problem with LEds is getting rid of the heat generated by high currents.
ymmv, mcd
1 hour ago, rmoore007ri said:
You can find "wedge base" LED bulbs with resistive current limiting and polarity protection from vendors like Allied. See
http://www.alliedelec.com/jkl-components-corporation-le-0504-01w/70314433/?mkwid=sFQxBG5rL&pcrid=30980760979&gclid=CNr6h-mq19ICFQ-Bswode9AGmA
bob
So, are they dimmable?:unsure:
Just kidding.
