Window regulator
So some bolt on the window mechanism broke and I'm getting stumped on where this level was attached too. I looked through my manual and multiple searches but maybe someone has a diagram or knows where it goes. In the second picture it is the piece with the empty hole. Thanks
There used to be (maybe it is still available) a Mercedes part that can be used to fix that. Do a forum search for window regulator and you should find it. There were some threads on it a bunch of years ago.
Good Luck,
Mike (#87)
Okay thanks! I looked at my other door and it goes behind the plate with the 3 screws by the hand crank. Idk if it is actually fixable or if I need a whole new window regulator, which I'll take a look now that I'm done working for the night. Thanks!!
Mike Self has a method for fixing that. I have also seen a method where a bolt head  is ground and a slot added for the spring. Just looked in my photos and only have a picture of the other side of that rivet. That's rectangular and secured in the hole by bending opposing corners.
rtheriaque wrote:
If the pin that retains the spring has sheared or worn out, drop me a PM--I did a column on how to repair that by modifying a steel bolt, which will last a lot longer than the original pot metal part...
3 minutes ago, '76mintgrun'02 said:
It looks like you need another one here
I am getting ready to install this one in my passenger door, so the window will finally roll all the way up.
Ahhh smart thinking! I'll have to do that
  • 3 years later...
