Stock spring question
These are my original springs, but I came up empty when trying to run the part numbers. I'd like to clean them up and repaint them, so my questions is which are the front and which are the rear, and were they originally black I guess, they have some other small spots of color - maybe just from the original fjord blue?
1969 2002 Granada, 2nd owner
1976 2002 Fjordblau (sold)
A few too many steering wheels
The paint marks are simply how BMW marked different springs, per application and/or spring rate. Red striped springs are often an optional stiffer / shorter, or heavier duty spring, for instance. Someone here can chime in on which is front vs rear. I can't remember. One should be a tad shorter than the other. White and blue stripes like yours shown are a common combo. I'd preserve / re-create those paint marks, if you're going for concours original appearance. It's a nice touch.
Part numbers on BMW parts are almost NEVER the actual part number of the item, but rather contract / catalog numbers used by their suppliers, etc. They're often infuriatingly close to real part numbers, but do not appear in factory parts literature.
Hope this helps at least a little bit.
Paul Wegweiser
Based on the information c.d. posted below, it looks like the blue and white striped springs are your fronts.
Do the rears have colors on them still?
c.d.iesel
  • c.d.iesel
  • Solex
  •  112
  • 12,172 posts
what I contributed many moons a go :
stock / oem 02 suspension coil spring colour codes and free length (not mounted length);
REAR SUSP SPRINGS
Green 776-803 lbs
White 750-776 lbs
Red 725-750 lbs
wire thickness 12.3mm (.049")free length unmounted 334.6 (13.17")
Heavy duty conversion ( for trailer towing )
grey/green 769-789 lbs
grey/white 730-769 lbs
grey/red 710-730 lbs
wire thickness 13.2mm (.052") free length of unmounted 324.2mm (12.76")
FOR touring - USE ONLY RED (in emergency WHITE is permissable
always use "1 Dot " rubber top cushion
FRONT SUSP SPRINGS
green/blue 635-656 lbs
white/blue 614-636 lbs
red/blue 595-614 lbs
wire thickness 11.8mm (0.465") free length unmounted 337.2mm (13.28")
Heavy duty conversion (only if rear is also converted)
green/grey/green 606/626 lbs
white/grey/white 584-606 lbs
red/grey/red 564-584 lbs
wire thickness 12mm (0.47") free length unmounted 345mm (13.58")
..........SO, AS YOU CAN SEE , WHEN INSPECTING UNKNOWN SPRINGS, THE FREE LENGTH CAN BE CLOSE, BUT IT'S THE WIRE THICKNESS THAT YOU NEED TO MEASURE CAREFULLY
THIS REF. FROM BMW REPAIR MANUAL (PRINTED) VOL.2
and. . . ..
rear coil spring upper rubber 'damper ring' comes in 3 heights:
28 mm height = 1 dot and green color code
33 mm height = 2 dot and white color code
37 mm height = 3 dot and red color code
Note: always fit top spring damper with 1 dot for Touring models (of course for orig springs)
check availability with dealer, one was NLA reciently.
the bottom rear coil spring rubber damper ring comes only in one thickness = 24mm
ref. 33-0/8 specifations BMW Repair Manual Vol. 2
AND........
SPRING TIME TECHNICAL DATA:
Message Title: Re: front or back?
10 1/4 " = Front
12 " = Rear
these are my 'old' Suspension Technique (dark GOLD painted) springs
measured "free" un-mounted length
and from factory manual:
13.28" = Front std
13.58" = Front Heavy Duty
13.17" Rear std.
14.25" Rear for Baur Convertible
...so according to this info, you could have shorter or longer springs in the rear than front ! What matters is wire diameter and lb. rating / spring load rating. So difficult to say with out knowing any part numbers or spring mfg. which of you springs belongs where. How about buying a new set of H&R 's which are clearly marked and you'll have a'fresh' set on the car. Throw some new BILSTEINS on while your at it.
Edited by '76mintgrun'02
Thank you all for the input. I like the originality of the color paint marks so I think I may just try to clean them up with a light resto and put them aside if I decide to reinstall them later when I tear down the car for an upcoming paint/bodywork. I'll do complete measurements on the size and thickness of the springs to make sure they back in the right place.
I am running IE stage ones right now with Bili HDs and it's a nice driving set up. But Im thinking of converting (almost) everything back to stock.
My struts were completely shot when I got my car so the first thing I did was replace them with HDs.
Of course, the 'while I am in there' bug bit and H&R springs went in at the same time.
So, I had very little experience on the original springs, to know what they felt like and if I had driven on them, the struts/shocks would have tainted my perspective.
I am thinking I will put the spacers back in up front and make some to go on top of the one dot rear pads I have, to raise the car a little, but keep the progressive springs.  Not today though.
I did save the original springs, of course.  IIRC, we have the same fronts and mine came with the lightest of the 'heavy duty' springs in the rear.  It also came with a trailer hitch, which came off after the third ding in my shins.
my orig '70 model springs are outside holding a tarp down on the woodpile.
They do have paint marks as I recall
Can take pics of woodpile if needed
1970 Agave work in progress
Born on May 14 1970 and delivered May 19th 1970 to NYC to Hoffman Motor Corp. Agave code 071
new guy
help appreciated!
other cars: 1991 318is / 1999 540iT
Hey John - look at the suspension thread Jason did on my car - he cleaned the springs on my car somehow.  You can see the paint marks really well in the pics.
EDIT:  The blue and white are the fronts (at least on my car).  The rears had yellow and green paint on 'em.
You could always ask him how he cleaned them.  Might have been gasoline.
The thread is in the Blog Archive section.
https://www.bmw2002faq.com/forums/topic/113719-1972-tii-suspension-restoration/
Scott
Edited by saaron
02ing since '87
'72 tii Euro  //  '21 330i x //  '14 BMW X5  //  '12 VW Jetta GLI
