1976 BMW 2002 - Calgary AB
DM914
Price: $11000
Description:
I've a '76' 2002 - with original engine and 4spd transmission -  Originally from TX - currently registered in AB - was repainted in TX prior to 2001 - overall very good condition - very solid since it was a TX car.  rockers, sills, all the seams are excellent -  I did a small 8" x 12" replacement patch on drivers side ( near the round plug thing )  from a factory replacement panel I bought from Wolf Steel -  I also replaced the spare tire bottom again with a factory report panel -   all the floors have had the tar coating removed - then I did POR 15 treatment - then Dyanmat sound deadener then installed a new underlay and carpet kit.
One great thing with this car is the electrical system is not hacked or modified - all the harness is in perfect as new condition.  Shifts well, stops well, rides really nice ( better than my new Ford F150)
Price listed is in USD for those south of the border - in CND it would $ 15,000
Some of the other stuff I did listed below -
New interior Carpet kit – new underlay – Dynamat sound deadener
New Replacement door panels and clips -
New door seals – new trunk seal
New water pump – New Radiator
New Rubber brake lines – New E-Brake Cables
New Rear Drums, New Wheel Cylinders, New Brake shoes
New Weber 32/36 progressive carb
Rebuilt axle shafts - cleaned lubed new allen bolts new CV boots –
New Wheel Bearings Front and Rear( inner and outer )
New ANSA Sport Muffler
Original Unrestored Tan/Leather seats
New fuel lines, Spark Plug wires – New Motor Mounts
Drivers floor pan replacement – spare tire well replacement ( Wolf Steel QC)
POR15 sealed – epoxy coated and primer – undercoated
Gas tank refurbished with POR tank sealer kit -  New Fuel Filler Hose Gaskets
New Locking BMW gas cap ( original included )
Upgraded shocks – Blistien HD & new suspension bushings
     Upgraded 14” BBS rims – New BFG radial tires
Reworked factory bumpers for better fit - shortened bumper shocks - shortened the rubber bellows -
Front turbo airdam – European rubber air deflector installed on rear deck
CIBE fog lights – with protective covers
FM/USB radio in factory console – upgraded speakers rear deck
I know these are worth a little more in CND than they are int he USA - only because of how few we see here and if they are here they are rusted junk.   This is not a project car it's a nice driver.  It's not a pebble beach concours example either, it has a few scuffs and bruises as you'd expect for 40+ year old car with 17+ year old paint...
It runs well - I have a small oil leak ( about the size of quarter if parked overnight ) that I haven't traced yet.  The Behr dealer installed AC functions but does;t blow as cold as it should thinking it might need a recharge.   The dome light doesn't function
For what I've seen for sale in CND I think I'm pretty close on price.    I do have the original TX title for this car if it's important for registration in the USA -  It was imported in CND back in 2004 I have that paperwork as well.  Previous Owner was based in TX then moved to CND ( Oil &Gas guy )
