Transmission flange removal - advice please
worzella
On 10/17/2018 at 11:53 AM, Kuntacharlie said:
Is the shim there to locate the output shaft bearing or is it there to locate the place where the  shaft seal rubs the output shaft , or something else?
Yes, there may be one or more shims beneath the output shaft bearing cover.  Don't loose them.
There may be one or more beneath the INPUT shaft cover as well.
Believe these shims set the shaft end play.
