5 speed conversion U-Shape tranny mount
odometergears
14 hours ago, mlytle said:
dont use the u shaped support.
No need to second Marshall's experienced comments, but if you look at the geometry involved the problem is apparent.  That bracket creates a lever arm for the weight on the rear of the transmission to pry against the original mounting brackets.  Given that the transmission and drive shaft need to be closely aligned, the bracket provides one more point where the alignment can fail.
BMWCCA  Member #14493
www.2002sonly.com
